-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Winter Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-winter-projects.html)
RSMike May 14, 2023 08:33 PM
Originally Posted by cmspaz (Post 11968985)
Since this is a hot spot for a lot of us SSB upright fam... I'm finishing up the install of mine.
I was previously running 3" brake ducts up front with a custom fabricated nozzle at the caliper, but those will no longer bolt up. So I'm curious what you more track-focused track guys are doing for cooling with this setup. I have some GT3 RS air guides I'm going to toss on the LCAs if I can't come up with anything better in the next couple weeks, but something a little more direct-fed would be ideal from my perspective. For reference: I'm stock caliper, stock 355mm rotor, PFC .01 pads, titanium shims, stainless pistons, SRF fluid. Any insight?
Like a wild Friday night - just jam it in wherever you can!
Keep the 3" ducts, might just need to modify the bracket to make it work?
I think SSB had the small threaded holes there to hold onto the ducts.
LCA scoops will help, but full ducted is the best for sure.
ViciousLSD May 14, 2023 09:39 PM
mudflaps?
https://cimg1.ibsrv.net/gimg/www.evo...cf06007205.jpg
https://cimg0.ibsrv.net/gimg/www.evo...a3064f0312.jpg
ViciousLSD May 14, 2023 10:04 PM
Originally Posted by Bee-Raddd (Post 11968978)
u guys all run way too much spring for circuit in my opinion. im 10k/12k and have heaps of turn in. Id suggest something else is out with your alignment if your getting alot of push. What are your other alignment settings, camber. toe, caster, bars and settings on them.
Its either that or your spring rate is out the window big time.
10k/12k range seems common with wheel to wheel racing and with very skilled drivers (not sure if left foot braking got to do with it). Personally with stockish fenders/liners and wider 200tw tires, stiffer springs is a must, especially if you autox too. I needed 15k front so my tires barely touches my 'tucked' fender/liners.
ViciousLSD May 14, 2023 10:13 PM
Originally Posted by Siluck2 (Post 11968923)
I had 12/18k rates and then did uprights and kept 12/18k and the most significant thing I noticed was the rear end didn’t feel as loose with cold tires. I think stiffer rear will help. I did a HPDE on 12/18k and it felt good, then went 14/24k and just felt easier to drive. I haven’t done another HPDE with the higher rates, but I’m on 12/24k now and mainly autox and it’s pretty dang amazing on street tires.
we did 14/20k(softer front bar, stock rear) on meathooker’s “budget build” and he said it felt great on track too with uprights.
man. last time I put on 22k rear springs my rear wheels were faster than my fronts, on a straight away, and spun.. I got called out by safety guys 2x, different days. I put those things away but looks like its time to try it again lol
Dallas J May 15, 2023 07:58 AM
Definitely have to understand the high rear rate has some caveats.
Most importantly, it still takes time for the rear tires to heat up. Longer than the front. And in that time, the rear will be pretty loose. Under 100mph, I full on send it. But higher speeds, gotta ease into things.
"You" probably need more rear camber than you have. -2.5-3 with stock uprights and -3-3.25 with SSB Rear uprights. The reason for more has to do with camber curves.
Toe is your tuning tool for rotation. Especially on/off throttle. Its even more pertinent while 3wheeling due to the thrust vector of that tire relative to the center of rotation. Center of rotation moves around depending on slip angle of both ends and when 3-wheeling you're likely near your peak slip angle with the center of rotation as far forward as it gets. Toe-in is going to reduce that rotation torque more and more as rear slip angle increases.
Bee-Raddd May 15, 2023 11:25 AM
I wonder if tyre type makes a big difference to what spring rate works also. Maybe on a semi slick or road tyre you need that extra spring rate to make the tyre work vs a slick?
I always found with the heavier springs especially on high speed corners it was like the rear had too much grip and the car would dig in and start oscillating/bouncing as your trying to power out of the corner. Maybe more camber would fix it. Definitely something to play around with on a test day some time.
Toe out was a good trick to get more rear grip when u need it also haha. can get hairy tho
Bee-Raddd May 15, 2023 11:28 AM
sorry for the small pic. My ducts were built into my caliper mounts. i had to do some minor shaving of the profile on the SSB uprights to make them fit but got them to fit.
https://cimg5.ibsrv.net/gimg/www.evo...478610ee71.jpg
Bee-Raddd May 15, 2023 11:31 AM
If anybody wants some light watching before bed tonight heres the full race videos from the other weekends racing
Race 1, Had an epic arm wrestle with Nick Jones in this one. both of us were pushing hard all race. just suffered from poor tyre warm up in the opening lap vs a car using tyre warmers which proved the difference.
https://www.youtube.com/watch?v=ySekOUe574Y&t=1s
Race 2, Full handicap race. we had a good start and got the jump on the competition. light rain limited our progress vs the slower cars up the road. can see i began suffering issues with a sticky shifter barrel and the gearbox was struggling to downshift in this one on occassion and the downshifts started sounding a bit rough.
Race 3, Off pole for this one thanks to our epic lap in the middle of R1. Had a poor initial launch and had to grab the clutch again. We had a good battle with Nick in the opening corners but really struggled for grip all race. Ran out of good tyres to use. Had a cool battle with Shane Whitley in the middle of the race but with the shifting issue getting worse he got the better of us. the shifting issue caused us to drop multiple issues with 2 corners to go which was real gutting.
Ayoustin May 16, 2023 09:53 AM
I wouldn't put cooling ducts on a time attack car. They add drag and weight to provide cooling that isn't needed. For a W2W car or one that is on track for 30+ minutes at a time where the braking system can reach full heat saturation they definitely help to regulate temps and extend pad life.
As for springs, spring rate changes more than 2-3k on a damper with linear pistons without a valving correction is just not a great idea. It's extremely common where I'll see guys toss on stiffer springs, end up chasing tire bounce issues, try to fix it by spinning knobs and then having new or worse issues. You can get away with it a bit more with digressive piston dampers but that's only because the high speed has a larger range of rates it can manage, the low speed damping will still be inadequate and you're still leaving performance on the table by not having the correct valving for the spring rate.
kyoo May 16, 2023 10:15 AM
i'm in agreement here. i dumped my ducts when i went ssb/ap racing, and have been realizing hot/hot/cool down is probably the best bet for time attack, and for engine happiness/power train & tires.
my ohlins are valved from factory to do 8/11, and I currently have 12's in the rear. i did have rear bouncing after the only change was going from stock knuckles to ssb f/r, but for whatever reason (maybe the 17s, more weight in the rear, idk), the rear bouncing seems to have stopped.
ps Austin, your relocation kit (https://www.wunderladenracing.com/pr...41076840169665) worked perfectly with the flex fuel kit I got. I can't get a great pic of it which is a bummer, but appreciate it & the rec to get tuned by raver.
kyoo May 17, 2023 06:36 AM
anyone got a spare intake manifold? I'm looking to get my stocker ported and coated but trying to save on some downtime. for part 2 of some upcoming work, i think im gonna get a 3" downpipe (up from 70mm/2.75") & ported stock intake manifold, and some minor this and that.
LetsGetThisDone May 17, 2023 01:04 PM
The downpipe I can see doing. But the ported manifold isn't going to do you anything on a low power setup.
kyoo May 17, 2023 04:10 PM
we have to take some stuff off and replace knock sensor, etc. so it's kind of just a why not sort of thing.
kyoo May 17, 2023 05:04 PM
https://ajpdistributors.com/products...turbo-downpipe
i just confirmed this price is correct....
is it worth getting maps for their flex joint, or no? the rest of my exhaust is OEM fitment
ViciousLSD May 17, 2023 08:15 PM
guessing only the flange opening is 3"
