Rockmanx Fp Black Complete Build thread.
Just got back from the Dynojet in Austin, about an hour away, and have the results for the first couple of pulls on the car.
It dynoed 584whp/536tq on 35psi of boost on E85. The car didn't even break a sweat on the dyno. Boost stopped there because that's all the Forge MBC would allow with the soft spring.
I'll post the graphs and more info later on.
Nice to know the blue bomber has alot more in it just one part holding it back that ill change instantly want that magical 600 for sure that tq is pretty nasty liking that so far man e85 im telling you
Looks good rock. Congrats! Those were right around the same numbers I had, except my tq numbers were around 575. I had a few things leaking that wouldnt let me go any higher on boost also.
more to update before jorge left to go tune a supra guezz what these numbers will go even higher oh my god i might have built this monster correct the blue bomber is begging for more. I need to change the forge MBC then it will go even higher tune was yet again a baby tune on it and its doing that. nick what were you final numbers?
Originally Posted by Nissan2Evo
Call me..I have to run to another dyno to take care of a Supra so I may forget.
The tune on it was soft also so you know, I wasn't pushing it at all.
. If i was not using it for show and wanted to strip it down then it will be a tough cookie to race but im not into tin cans
Rock, be careful with the Forge heavy spring. Even at its lowest setting on my car it would make 32 PSI spike. On really cold days she would give me about 35 PSI. I was on pump gas, mind you so this wasn't very safe. I had to take the MBC off and only use it when on race gas.
See if you can get a hallman with a ceramic ball and heavy spring. They seem to work a lot better and have a wider/higher range of boost to choose from.
