View Poll Results: What should I do with the wing?
Wingless
30.77%
Keep it
69.23%
Voters: 13. You may not vote on this poll
Project "Silver Bullet" LR2.4, FF EFR8374, total transformation
Old Sep 28, 2011 | 07:51 PM
project_skyline's Avatar
Project "Silver Bullet" High Altitude monster
Update: It's ALIVE!
This is the world's longest build. Started over 2 1/2 years ago. Now it is finally time for the beast to run again. Goals for 2013 are 9's at Bandimere Speedway
Brief history:
Owned for 3+ years, stock motor developed low compression November of last year and blew out turbo seals. Stopped driving it and tore the car apart.
Motor had 105k miles and has been modified by both the previous owner and myself since the first 5k miles, bought brand new in 2002.
Ran a best of 11.97@115mph @ 5800 FT with the low compression on e85 w/ bolt ons, stock turbo.
New setup mod list:
ASF Machine built LR2.4
-Manley race crank
-Manley 10.5:1 pistons w/beef cake pins
-Manley Turbo tuff I beams
-ACL Race bearings
-MAP super duty headstuds
-ARP main studs
-ER modified Water pump
-Cometic gasket
-deburred and polish oil pump
-BS delete
-Kiggly regulator
-Fluidampr harmonic balancer
ASF Machine prototype port and polish head
-GSC stock size vales
-GSC beehive valve springs
-GSC R2 evo 8 cams
-ASF spec valve job
Custom FF manifold
Precision 6766 T4 1.15 A/R turbocharger
Turbosmart duel comp-gate 40's
2.5" IC piping with 2x Turbosmart raceport BOV's
ETS 3.5inch IC
Ported custom shaved and polished Intake manifold w/65mm TB
BR exhaust
FIC 2150's
Turbosmart FPR1200
FIC fuel rail (waiting to install)
-8AN feed (waiting to install)
BR double pumper
Turbosmart duel stage boost controller
Stock ECU speed density by Me
Omni 4 bar map sensor
Shep trans w/ all options but 4.11
Shep trans stage 3 transfer case
Exedy triple disc with ACT monoloc
STM clutch line
8 disc rear diff mod by Elevated Tuning
TS motor mount inserts
First start up
Spent a decent amount of time re-organizing and tidying up the engine bay. Check out the before and after.
Washed the car today with my friend, it was pretty dirty. I'm gonna start body work on it soon so I can paint the ugly bastard!
Numbers and drag times soon to come
Old Sep 28, 2011 | 08:05 PM
awdturbo8's Avatar
Awesome build man. Can't wait to see the finished product and the numbers the BW will give you. Good luck with everything.
Old Sep 28, 2011 | 08:10 PM
evoforstevo's Avatar
in on the second post for what sounds like a BEAST build
Old Sep 28, 2011 | 10:17 PM
S13 Curtis's Avatar
+2mm oversized valves damn. Nice build.
Old Sep 29, 2011 | 12:52 AM
dtrackstar's Avatar
looks like an awesome build. Whose building you the ff manifold? twin scroll right?
Also, what's the cars purpose? street? track?
Old Sep 29, 2011 | 04:44 AM
MaD_CaNaBiCe's Avatar
wow interesting build! Care to share more info on the terms "deburred" and polish oil pump? Pm me if you dont wanna discuss it here.
Old Sep 29, 2011 | 07:44 AM
AMF's Avatar
AMF
Subsribed!! I thought you're selling your bw turbo. Is this the same one? or you have an extra one?! I'm anxiously waiting for the efr 8374 or 9180 results before making my final decision on the turbo. 7670 is pretty convincing so far . My fabricator told me that it is very possible to fit an efr turbo without sacrificing the a/c and radiator even with a t4 ts setup. ( non FF ) It has to be external wastegates though. I'm fine with 2 external dumptubes
Good luck with your build. I'm sure this is going to be a beast!!
Old Sep 29, 2011 | 11:53 AM
awdturbo8's Avatar
I would like info on this too. And also your modified water
Pump. They both sound interesting. You can pm me if you want. Thanks
Old Sep 29, 2011 | 02:21 PM
blknblubkrdude's Avatar
Sounds like it is going to rip! Goal PSI? Hopefully everything holds up!
Old Sep 29, 2011 | 03:44 PM
BOOSTINAT30PSI's Avatar
In for more
Old Sep 29, 2011 | 05:31 PM
BOOSTED_H22A's Avatar
Subscribed to this thread for sure! Good luck with everything.
Old Sep 29, 2011 | 10:20 PM
Dantheman11's Avatar
sub'd, build looks sick man.
Old Sep 30, 2011 | 11:37 AM
A guy on here, he makes a bad *** manifold for good price. Its not twin scroll, those are impossible to find right now.
The cars purpose right now is going to be daily street use for a while until I get a beater for the winter. I'm going to be dragging it too, want to run 10's on pump and 9's on e85. Not sure how far I want to go with that though.
The spring time I'm going to focus on improving the handling and braking aspects of the car for road racing, maybe some auto-x but not sure at this point.
Ya we are going to R&R the oil pump to deburr and polish the drive gears. Basically it will help reduce wear and my builder said he has seen the gears start to eat into the housing so it will help prevent that.
I was selling for a friend and I finally decided I wanted it rather then a 6266 or HTA86.
IIRC from my reading.
The water pump has to do with the 6mm taller deck, what happens is the pump doesn't cover one of the water jackets completely so it requires a spacer or a pump that is modified.
Umm probably 40+ psi, whatever it takes to destroy some records.
Old Sep 30, 2011 | 01:04 PM
SmurfZilla's Avatar
Nice. I wanted this turbo but the wait and the inability to bolt it up to my manifold without modifying the body was a deal breaker.
Old Oct 30, 2011 | 06:42 PM
Small update. Blueprinted the engine today. The align hone, bore and hone are done. Just need to file fit rings and assemble.
Here some pictures.
