Going under the knife.. MAP 2.3L\EF4 Build
Old Feb 4, 2012 | 08:19 PM
Revobasher's Avatar
Dropping my car off at MAP tomorrow! Chris and the entire team have been great and I cannot wait to see the end result and final numbers.. predictions?
Mods ***UPDATED 2/15/12***
Performance\Engine:
MAP 2.3L Stage 2
MAP EF4 Ported Turbo
MAP Stage 1 Head
MAP Ultimate Duty Rods
MAP Ultimate Duty H11 Head Studs
MAP 25psi Actuator
MAP Custom Air Intake with Spectre Filter
MAP Cam Sensor Shield
MAP Custom UICP
MAP Tubular Long Runner Exhaust Manifold
MAP o2 Housing
MAP AFPR Install Kit with AEM FPR
Wiseco Pistons 1400HD
GSC S2 Cams
Beehive Springs
ARP Main Studs
ACL Bearings
FP Exhaust Manifold Stud & Nut Kit
AEM Tru-Time Cam Gear
Zaklee Clear Cam Cover
Gates Timing Belt
SpoolinUP COP
Speed Density
FIC 2150cc Injectors
MIL.SPEC TB Seals
Walbro 400lph Fuel Pump
Kenne Bell 40amp BAP
EGR Blockoff
ETS 3.5” FMIC
Muse LICP
Turbosmart 50mm Race Port BOV
DC Sports Catless Downpipe
GReddy Evo2 Catback
Hallman Pro MBC
Grimmspeed EBC
Suspension:
Robispec KW V3 Clubsports
Robispec Rear Sway Bar
Whiteline Front Roll Center Kit
Whiteline Rear Trailing Arm Bushings
Whiteline Rear Bump Steer Kit
Vorshlag High Castor Front Camber Plates
Stoppage:
StopTech Slotted Rotors, front and rear
Hawk HPS Front Pads
StopTech Street Rear Pads
StopTech Stainless Braided Lines
Motul Fluid
Trans:
5 Speed RS Swap with all new parts
ACT HDG6
Competition Forged Steel Flywheel
Speed Source Shifter Base and Cable Bushings
Wheels\Tires:
Summer:
Enkei RPF1: 17x9.5 +18 front, +38 rear
Falken Azenis RT-615k 255/40/17
Drop Engineering open-ended Lugs
Winter:
Stock MR BBS
225/45/17 Semperit Winter Sports
Interior:
Gruppe pod
Prosport HALO Gauges-- Wideband, Oil Pressure, Boost
Trustz Gauge Overlays
LED bulbs
Alpine CDA-105 Headunit
Boston Acoustics SC65 Speakers
Exterior:
Evo 7 Tail Lights
eBay Poly Lip
Couple in progress shots:
Old Feb 4, 2012 | 08:21 PM
SDevo13's Avatar
I vote you join me at BiR for an HPDE this summer ^_^. Subscribed
Old Feb 4, 2012 | 09:13 PM
Drifting Away's Avatar
Subscribed , thats going to be a killer setup.
Old Feb 5, 2012 | 01:17 AM
DJAfterShok's Avatar
subscribed... curious to see those EF4 results!
Old Feb 5, 2012 | 12:26 PM
Svendiesel's Avatar
Nice good luck, they'll take good care of you.
I say mid to high 500 easily and probably around the same for torque if this is on E85. Your injectors are going to be forced hard though I feel.
No head work??
Old Feb 6, 2012 | 10:17 AM
Revobasher's Avatar
Dropped off car at MAP today!
I am curious to see how the fuel plays out... I am guessing I will need Walbro 400, FPR and bigger injectors.. we'll see though.
Head is getting MAP Stage 1 treatment.
Old Feb 6, 2012 | 01:27 PM
Revobasher's Avatar
A few hours after dropping it off and motor\trans already out. I guess MAP has done this before. :P
Old Feb 6, 2012 | 02:09 PM
Revobasher's Avatar
Heads off.. short block looks pretty good!!
Old Feb 6, 2012 | 05:27 PM
ziad's Avatar
looking awesome mate
Old Feb 7, 2012 | 04:48 PM
Revobasher's Avatar
Coming along.. Clutch and flywheel got damaged when separating motor and trans. Bummer. I'll be going with an ACT HDG6 sprung and comp flywheel. Also upgrading fuel pump, injectors and adding a FPR.*
Old Feb 7, 2012 | 04:52 PM
Kidloco51's Avatar
Old Feb 7, 2012 | 04:54 PM
CurseDSM's Avatar
Looking good. I can't wait to see what kinda #'s your gonna make and how she performs definately subscribed.
Old Feb 7, 2012 | 08:45 PM
Ramonski's Avatar
This build looks simply AMAZING ! EXACTLY the type of build I would like to give my evo one day. Good luck bro and DEFINITELY sub'd
Old Feb 7, 2012 | 08:57 PM
Revobasher's Avatar
Thx
Also.. Check it.. *Even outside of the car with easy access and a multitude of tools there was no way the pressure plate was letting go without damaging the retaining ring
Old Feb 7, 2012 | 10:56 PM
tscompusa's Avatar
should of released it while engine was in car.
