MAP Stage 2 LR 2.4L Build
Old Jun 8, 2012 | 09:15 PM
  #196
Blue91lx's Avatar
Originally Posted by DarkIX
Wow kudos man!! i know i don't have the patience to deal with all that wiring. Looks good though!!
Thanks man! I definitely think it was worth the hassle. Now if I could just stop hitting road bumps this car would be on the road.
Old Jun 9, 2012 | 10:12 AM
  #197
Blue91lx's Avatar
I took a break from the wiring stuff and mounted my AFPR. This is the only decent place I found that I could put it.
Old Jun 9, 2012 | 10:36 AM
  #198
Blue91lx's Avatar
Oh, and since I'm all about spool/torque, and since I couldn't stand the idea of not going T3, AND since I hate stock frame turbos, I bought a Cast T3 kit with Bushur O2 housing and Dump tube.
I'll be running an HTA 3582 (with a .63 housing) and have a goal to hit full boost by 4000 RPMs on the 2.4L. The big stock frames are far too laggy without the punch up top that I'd like to have.
Keep in mind this setup probably won't go on until next Winter, I still want to be prepared .
I may have Curt Brown work his magic on this manifold as well. We'll see.
Old Jun 10, 2012 | 10:08 PM
  #199
Blue91lx's Avatar
I got my other NT03s back from their refinish! Now they all look brand new.
Modified my Evo VI Radiator to work with an VIII/IX fan, so if one goes in the future it will be easily replaceable.
The tuck is done!! I'm just waiting on loom. Here are a few teasers with just the wrap, no loom.
Mounted the catch can and made a little bracket for my Turbo Oil Feed Line so it sits nice and snug. FP tells you to route it under the front of the car, but that just seemed far too risky to me, as it's fully exposed to road debris and rocks.... I'd rather protect that line.
Now all I'm waiting on to finish the car is an 02 Dump....It's always thing after thing. Every little thing is buttoned up and ready to go!!
Old Jun 11, 2012 | 04:55 PM
  #200
Blue91lx's Avatar
Old Jun 11, 2012 | 10:03 PM
  #201
akauf's Avatar
dude, come on, do you really think your the first person to use a 4g64 belt and discover that it times perfectly. It doesn't, your timings off and your in the wrong dowels on the came gears...
this has even been discussed here before:
https://www.evolutionm.net/forums/ev...g-marks-2.html
listen to freddie in your other thread...
If you still don't believe it, degree your cam and see where your actually at based off of measurements of the cam profile not the markings. It WILL be off...
Old Jun 11, 2012 | 10:47 PM
  #202
Blue91lx's Avatar
If you read the Fidanza cam gear manual, you would see that the EVO hole is for an Evo 1-4 and for an Evo VIII-IX you're supposed to use the hole not labeled Evo. I found that out awhile back when a bunch of people told me what you just told me and my timing was completely off until I read the manual and put the dowel pins in the correct holes.
I did this on cam gears with only an Evo dowel pin and the results were the same.
I can't get my timing to be advanced a half tooth...unless you purposely change it from the beginning.
Old Jun 11, 2012 | 11:01 PM
  #203
stanlsha's Avatar
The timing with a 4g64 belt on a 2.4 lines up as it would w a 63 belt on a 2.0 it's fact it's been done over and over again on multiple motors to the same effect
Logically thinking if you turn your cams bak one tooth and then turn your crank back one tooth everything must stay in sync from that point on yes? Yes...
Thus when you go to tdc on the crank w a 63 belt you are off half a tooth due to 6mm of deck height. Now go measure the distance from tooth to tooth on a belt it's in the realm of 11 mm therefore 6mm of that is taken from the deck leaving you off by 5mm or about half a tooth which is why you need to degree the cams.
W a 64 belt the 6mm from the deck + the left over ~5mm is made up for in the extra one tooth thus leaving you with as close to perfect timing as one can get (same as timing a 2.0 w a 63 belt) varies a degree or two depending on how much was cut from you head and block etc
Old Jun 12, 2012 | 12:50 AM
  #204
Blue91lx's Avatar
And we have a final consensus!!!
Originally Posted by 94AWDcoupe
sure,
the timing changes when you move head up or down, move head up and cam gears rotate right. move head down (as in head shave) and gears rotate left.
tall 2.4 block raises head by 6mm. this will rotate gears by 3.75 degrees.
the gears rotate because belt tooth spacing/length does not change.
BELT LENGTH DOES NOT CHANGE TIMING. it only determines how much slack you have on the tensioner side . the distance from gear to gear remains a fixed constant.
dont know how else to explain it. I assure you I am correct. only way longer belt would change the timing is if you rotated the gears 1 full tooth during install. and you can do that with 63 belt!
Old Jun 12, 2012 | 05:37 PM
  #205
Blue91lx's Avatar
Today I added up everything I bought since I got the car last August and it was $12,229.86. That's not including everything I sold off the car.
Not nearly as bad as I thought it was going to be.
Old Jun 12, 2012 | 05:45 PM
  #206
Yme's Avatar
Yme
dang
Old Jun 12, 2012 | 05:49 PM
  #207
Blue91lx's Avatar
Originally Posted by Yme
dang
Haha I thought that was cheap for essentially a fully built car with all maintenance up to date, no?
Old Jun 12, 2012 | 05:52 PM
  #208
Yme's Avatar
Yme
I think when you hit me with a 5 figure, it looks more than it actually is, considering all the work and parts that go into it.
Old Jun 12, 2012 | 06:00 PM
  #209
Blue91lx's Avatar
Haha exactly. That's literally every single part I've purchased, plus up-keep since last August for what once was a piece of junk car. I thought it'd be closer to $20K to be honest.
Old Jun 12, 2012 | 06:03 PM
  #210
Yme's Avatar
Yme
That's really good!!! yeah when you think about it 20k is more realistic lol
