MAP Stage 2 LR 2.4L Build
Old Jun 28, 2012 | 12:57 PM
  #256
Blue91lx's Avatar
Originally Posted by Adam Brunson
Incorrect, one is for a tire gauge to monitor the air while you fill it. I have the same wheels
Is your Washer/Dryer close to the garage?
Gah, I was wrong again. A wheel guru told me that and I trusted his opinion.
The dryer room is the closest room to the front door (which is closest to the garage), other than the living room. So, comparatively speaking, it's about as close to the garage as it's gonna get.
Old Jun 28, 2012 | 02:45 PM
  #257
Adam Brunson's Avatar
Distance in feet. LOL
Old Jun 28, 2012 | 05:05 PM
  #258
Blue91lx's Avatar
I shall measure.
But until then..... Pictures!
Old Jun 28, 2012 | 05:17 PM
  #259
06evors's Avatar
Love the last shot. The 7 tails/JDM rear it looks perfect.
Old Jun 28, 2012 | 09:51 PM
  #260
Blue91lx's Avatar
Thanks, man! The car has quite the identity crisis .
Old Jun 29, 2012 | 05:50 AM
  #261
7/8/9/JDM.. WTF MATE! LOL
Joo has fender roller?
No need to measure, just guess hahaha.
Old Jun 30, 2012 | 09:34 AM
  #262
Blue91lx's Avatar
I like all Evo's, so I wanted to combine my favorite parts from all of the cars into one vehicle! My interior is the same way!
I would say a 100ft cord would cover it, that way you'd have room to move around in the garage, as my bay is the far bay.
My friend has an Eastwood roller that he lets my friends and I use whenever, and I have my own heat gun!
Old Jun 30, 2012 | 09:38 AM
  #263
tsidrift1's Avatar
Loving the 7 tails, thinking of getting a set myself.
Old Jun 30, 2012 | 06:39 PM
  #264
Blue91lx's Avatar
It's one of my favorite appearance mods for these cars, for sure.
On a sweeter note......................
THE EVO RUNS
Thanks to JohnBradley (Aaron)'s SD start up/break in tune, she runs great. Did the 20 minute idle and changed the oil. Normal break in metal, but nearly nothing on the magnetic plug.
As soon as I can throw some insurance back on it I'll go out for my 50 mile drive and seat the rings.
Old Jul 1, 2012 | 04:18 PM
  #265
Blue91lx's Avatar
Did my 50 mile break in drive, and it went very well! I accidentally hit about 7# of boost for a split second and hit a cut, but once I shut the car down and restarted her it was fine.
Oil pressure is great and consistent, fuel pressure is at 40PSI, and coolant temp is right where it should be.
Going to be logging all this week!
The only thing I'm battling is a high idle, around 1400.
Aaron set it to about 1050 via the tune, I messed with the TPS and that changed nothing, I messed with the idle screw and that did nothing.
I also went over ALL vacuum lines and found no leaks!
I did change the scaling a bit, and that helped a bit, but still didn't bring it down enough.
I'm thinking my cam timing is still off a degree or so.
Old Jul 1, 2012 | 07:57 PM
  #266
Evolution IVGSR's Avatar
What is your cam timing at? That is still one of the only questions and concerns I have about doing on mine. I have heard so many different ways people are setting them to.
Old Jul 1, 2012 | 08:00 PM
  #267
Blue91lx's Avatar
I have mine each 2 degrees advanced and I think I need to go one or two more. There are 10 million different things people say. Check out this thread I made a little while back. I literally can't even tell you what's right, as it's still the most unclear thing ever.
Check out this thread I started to confuse yourself more:
https://www.evolutionm.net/forums/ev...ctly-time.html
Before I do any WOT tuning, I'm going to most likely take my car to CBRD and get them to actually "degree" the motor, as there is no other way to truly find out what is correct.
Like this:
http://cranecams.com/uploads/instructions/803.pdf
Old Jul 1, 2012 | 08:14 PM
  #268
Chef-j's Avatar
Your car looks awesome!!!
Old Jul 1, 2012 | 08:28 PM
  #269
Blue91lx's Avatar
Thanks, man! I hate most Apexi Silver cars, so I was on a mission to make myself pleased with the color of my car . I'm satisfied with the way it turned out.
The only other thing I've been thinking is........A black roof on a silver car.
Old Jul 1, 2012 | 08:31 PM
  #270
Chef-j's Avatar
Maybe carbon wrap btw, did you cut the misu logo on front? Or remove whole grill?
