MAP Stage 2 LR 2.4L Build
Old Jul 16, 2012 | 06:35 PM
  #316
Adam Brunson's Avatar
Levar - what are you doing?
Old Jul 16, 2012 | 08:15 PM
  #317
Levar's Avatar
Veteran: Army
PM sent, my friend.
Old Jul 18, 2012 | 12:01 PM
  #318
Blue91lx's Avatar
Hit 500 miles, woot woot!
I'm so fed up with all of my failed attempts to log my wideband I just bought one of these:
http://www.streettunedmotorsports.co...rial_cable.htm
Old Jul 19, 2012 | 06:55 AM
  #319
Hope it works out homie!
Old Jul 19, 2012 | 08:36 AM
  #320
Blue91lx's Avatar
Thanks, mang! I hope it does too . The car runs awesome. Since the idle was put in open loop, it hasn't missed a beat yet in the first 500 miles. Not one stall, hiccup, or anything.
Adam, do you happen to have a degree wheel? I would really like to degree my motor so I know exactly how far I'm off before I start WOT tuning.
Old Jul 19, 2012 | 09:35 AM
  #321
I do. I'll have to find it, but your going to have better luck snagging one off summit.
Here;
http://www.summitracing.com/parts/SUM-G1057/
Old Jul 19, 2012 | 11:10 AM
  #322
Blue91lx's Avatar
Here;
I'll order it up. I may need a hand degreeing the car as I've never done one before.
However, the only reason I'm degreeing my motor is because of my Fidanza Cam Gears......Maybe I'll just pick up some normal cam gears and do the ole 3.75* deal.....
Old Jul 19, 2012 | 11:16 AM
  #323
What is wrong with the fidanza gears? It should be the same thing.
Old Jul 19, 2012 | 11:27 AM
  #324
Blue91lx's Avatar
Fidanza's castings have been randomly different throughout their entire time of production. On my 2.0L I had them in the Evo hole, and to even get them to run the ignition timing had to be completely wack. Put 'em in the DSM hole and they worked perfect and were perfectly in time.
So, I THINK that they're on when in the DSM hole, but will never know for sure until I degree the motor.
Here's another post showing how the set that the had was off in both dowel holes:
Originally Posted by 94AWDcoupe
had to go check these fidanza gears. I was certain we used the DSM holes and now I remember why. these fidanza gears are a night mare. they arent correct using either hole. the evo hole makes the mark off one half tooth. the dsm hole makes the mark a full tooth off. thats why I used the dsm hole. just move the mark over one tooth. cams are far closer to straight up that way.
Old Jul 19, 2012 | 11:43 AM
  #325
Spec-Ops1's Avatar
I got rid of the fidanzas and moved to a set of AEMs as of late...
Old Jul 19, 2012 | 11:45 AM
  #326
Blue91lx's Avatar
Good man. That's where I'm at with all of this BS. Not to mention I have to hold the back of each bolt to tighten them down after I degree them!!
Awaiting a returned phone call to order some AEM gears.
Old Jul 19, 2012 | 11:48 AM
  #327
Spec-Ops1's Avatar
I had no issues with the Fidanzas, just confusing... and since you have S2s, I am curious as to how the cams will be degree'd, please post that info when you get it!
Old Jul 19, 2012 | 11:51 AM
  #328
Blue91lx's Avatar
I'm curious as well. For starters I'm going to do the AEM gears and just advance them 3.75* each, and later when I get some extra time will degree the motor and see what exactly it comes out to.
I'll surely post up when I do that! Fingers crossed the normal cam gears will solve this mess.
Old Jul 20, 2012 | 12:39 PM
  #329
Blue91lx's Avatar
I've been denying that I needed these for awhile. Such a high quality piece, especially compared to the Fidanzas.
Old Jul 20, 2012 | 07:48 PM
  #330
Pirana's Avatar
I love those if they came purple more than the HKS!
