All Hail Megatron Build - MAP 2.4LR
I love your frankness, my friend.
I got a possibility of it being the power steering pulley as well as the bolt that goes into the pulley was not installed during the build. I was also told that it sounds like the bearings are shot. I understand that things like this happens. Assuming this is the case, I will make a post on the Mitsubishi Parts thread on here to see how much the power steering pulley costs as I was told that it is expensive. My two main questions are:
1. Can the pulley be installed without removing the entire engine?
2. Can I still safely drive the car until I get it fixed?
I will check it out after the holiday as I have the car stored as I am on my way to visit family. Assuming that I can move it, what is the course of action?
https://www.evolutionm.net/forums/evo-how-tos-installations/467552-how-timing-belt-balancer-shaft-belt-accessory-belt-replacement.html
I am back home and on the grind to determine what the issues are with Megatron. I am going to see if the belt is just in the need of lubricant. I remember this being an issue with my first EVO.
