Badev0's Build Thread *Part 2*
Old Jun 8, 2013 | 06:23 AM
  #526
badev0's Avatar
Yeah the place doing it is no stranger when it comes to HG sealing. It'll be picked up Sunday and off to the shop
Old Jun 9, 2013 | 05:22 PM
  #527
TurboTravis's Avatar
Originally Posted by MitsubishiJoe
Where do you monitor water pressure? WHat is the easiest place to use that requires no modification?
If you're comfortable drilling/tapping, use the bottom half of the thermostat housing. If not, "T" into any of the rubber coolant lines. Autometer sells several different styles of water pressure gauges.
Old Jun 9, 2013 | 06:49 PM
  #528
CurseDSM's Avatar
Originally Posted by badev0
If your car was leaking coolant, cold or warm, then you simply did it wrong my friend. There are plenty of street cars out there without ANY issues on a copper gasket.
Idk once I got rid of the copper gasket everything stopped leakin? Haven't had an issues since. I mean Idk how you would do a head gasket wrong, specially with a copper head gasket being its pretty self explanatory.
Old Jun 9, 2013 | 07:20 PM
  #529
batty200's Avatar
So you are using a receiver groove ? Good stuff.
Old Jun 10, 2013 | 07:30 AM
  #530
badev0's Avatar
Turns out the car is now getting a TRE 12-plate max lock rear diff while its down.
The rear diff in my daily driver burnt up from using the OEM spare ( I didn't think this would be an issue since the car is on OEM wheels with OEM tire size). Well, mitsubishi is stupid and turns out the diamater of the spare is 23.x and not 25.3 (stock diameter). I took the stock rear diff out of the black car and put it in my daily driver. Burnt up diff from daily is getting the rebuild/upgrade service from TRE which will go in the black car. Kind of works out
Did you do the receiver groove in block? (or head). If not, that's an instant disaster. You also have to seal the water jackets correctly or they will leak.
Yes sir.
Old Jun 10, 2013 | 07:38 AM
  #531
CurseDSM's Avatar
Yes
Man if its not one thing its another
Yeah the block got the receiver groove and the head had the oring. I believe it was because when I had the head done they used ss oring material and didn't seal that great. Again once I swapped to the oem mls I never had an issue.
Old Jun 10, 2013 | 07:42 AM
  #532
badev0's Avatar
SS oring is what you would want to use. I'm guessing your car sealed compression very well but was leaking from the water jackets?
Old Jun 10, 2013 | 07:44 AM
  #533
Bruzewski's Avatar
Dang are you kidding me?
Old Jun 10, 2013 | 07:46 AM
  #534
badev0's Avatar
Nope, really sucks!
Old Jun 10, 2013 | 07:50 AM
  #535
CurseDSM's Avatar
Honestly Idk where it was coming from. It did push coolant for a bit till I got tired of it and was able to take it down again. I made sure everything would seal but it just didn't like the setup I guess. After I did the hg change I drove it hard for about 5 months before I moved and found the new body and it never once leaked. I guess it is just one of those weird things.
Old Jun 10, 2013 | 08:13 AM
  #536
antilag_200's Avatar
When it rains, it pours
  #537
badev0's Avatar
it does indeed...
Old Jun 10, 2013 | 08:15 AM
  #538
CurseDSM's Avatar
it does indeed...
I guess the way you can look at is at least you had a back up plan and your not left without.
Old Jul 2, 2013 | 04:40 PM
  #539
badev0's Avatar
TRE 12-plate max lock rear diff... TRE FTW!
Here's a quick teasier video I made for a film i'm making for my friend who built the cage
Old Jul 15, 2013 | 12:25 AM
  #540
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
amazing build and nice car, well done sir. i'll be in the detroit area next month, stationed there for 4 years and i plan on going to the shoot out. i don't know that i'll run since my tech support and friend/builder is back in MD. keep up the good work.
