Scotts 2.3 stroker build
Old Nov 25, 2012 | 04:43 PM
evoscott's Avatar
Decided to finally post my build. 99 percent complete waiting for oil cooler and then off for tune. Big thanks to the guys at TrackFrorged for putting up with me. More pictures to come along with dyno sheets
2.3L Stroker:
wisco .20 over pistons
Maney Rods
Manley Stroker crank
ACL Berings
Arp Rod Bolts
ARP head studs
GSC S1 cams
fuel pressure regulatior
walbro 255 in take
custom serg tank with bosh 44 external pump
FIC 1250 injectors
koyo radiator
Perrien boost controller
Turbo Kit:
Precision 5862 with anti surge housing
Trackforged manifold
Trackforged downpipe
Tial 44m wastgate-atmostpher dump
3 inch straight pipe to magniflow muffler
ETS 3in intercooler
Trackforged intercooler piping
Turboxs BLOV
Interior/Exterior
AEM wide band
AEM oil pressure
Do-luck carbon fiber lip
Wingless trunk
MR Bilstiens on Tien springs
HKS turbo timer
Attached Thumbnails Scotts 2.3 stroker build-sss.jpg   Scotts 2.3 stroker build-ssss.jpg
Old Nov 25, 2012 | 10:02 PM
dtrackstar's Avatar
Looking forward to more pics. S1s are a little out of place in your build though haha
Old Nov 26, 2012 | 10:08 AM
evoscott's Avatar
Yah was thinking doing s3 depending on power it makes
Old Nov 26, 2012 | 10:35 AM
jmcmill3's Avatar
yeah, thats about what you would want for a motor that big... but it looks like you are going for more response more than anything, so maybe you are on the right track
Old Nov 26, 2012 | 10:51 AM
evoscott's Avatar
Ya I was just going to do a stock fram stock 2.0 but as soon as I started digging into it the whole build took a gigantic turn haha
Old Nov 26, 2012 | 03:03 PM
jmcmill3's Avatar
lol yeah i started the same.. stock block w/ fp black.. then popped that.. so said f it... get a 2.4 stock head... then said why not build the head.. then said why not upgrade to a t3 turbo... seems like it never stops.. hopefully it will one day but i dont want to get bored and eventually try to sell it.
Old Nov 26, 2012 | 05:35 PM
evoscott's Avatar
Yah I don't want to do this twice so I just said f it and did nothing but work sleep eat for what she is now.. Hopefully she will put down some good numbers and scare the crap out of me
Old Nov 26, 2012 | 08:31 PM
WikdEvo's Avatar
what are your hp goals for this build? Looks like the s1's and the single whinebro are going to hold you back.
edit* Just saw that you had an external fuel pump. carry on lol. Still, the s1's and the injector's look a little small. Are you going to be running strictly pump gas on this?
Old Nov 27, 2012 | 09:05 AM
evoscott's Avatar
Goals where when I built the car was 500hp 500ft lbs.. But at the same time have enough room to play with if I get bored with that and wouldn't have to re-build again. The car will be on pump gas for now.. But I plan on doing a duel map for e85 but at that time I know I will need more injectors and prob do s3s.. I just didn't want the car to have that laggy late spool feeling
Old Nov 27, 2012 | 05:58 PM
jmcmill3's Avatar
you may wana consult English Racing.. they suggest S3's with 2.3s and 4s period for good reason..
Old Nov 27, 2012 | 07:53 PM
evoscott's Avatar
Yah I have a different builder than them..
Old Nov 27, 2012 | 08:49 PM
Lucas English's Avatar
Hope we are still tuning it but if not I would love to see what it does on our dyno again someday.
I think the S1's were from the stock turbo build.
I run S1's in my 2.4 I know S2s will make more hp but I like to have my smooth old man idle.
I am a fan of the S2 as the best street cam. The amount of idle quality and hp loss below 5k is not worth the little extra hp at 7k in my book for S3's
Old Nov 28, 2012 | 01:31 AM
JScocchio's Avatar
Question
I am a fan of the S2 as the best street cam. The amount of idle quality and hp loss below 5k is not worth the little extra hp at 7k in my book.
So, I am just trying to make sure I am understanding what you are saying here, as I am looking to do a low end focused 2.3 build (and I still have my current S1s from my stock block)...
In your opinion, all else being equal, if you are focused on the below 7k range in the powerband S1s may be a better option than S2s? I was under the impression from other posts (from English as well as other shops) that S2s were outright better, no loss across the powerband, only gain.
Just trying to understand.
Old Nov 28, 2012 | 08:43 AM
Yes in power band the S2's are the better then S1's except for idle. S1's can sound almost like stock on a larger motor ware S2's will have a very camed out idle which most people like. This is all EVOVIII info. A IX with Mevic can make S2's idle real smooth.
I can see ware my post looked a bit off. I was comparing s2 to s3 in the above comment.
Old Nov 28, 2012 | 12:41 PM
evoscott's Avatar
Ya I will be giving u guys a call when it's done.
ExtremeDSM
For Sale - Cars For Sale
11
Mar 22, 2017 08:18 AM
03Roush2
Jan 6, 2017 01:49 PM
My03evo
17
Jan 6, 2017 10:36 AM
Alchem1st
35
Dec 3, 2013 05:35 PM
jamie_v1
Mar 27, 2011 07:54 PM
