New WW IX MR
Old Mar 19, 2013 | 09:56 AM
  #91
heel2toe's Avatar
Yeah I would definitely keep the height where it is for now and see how the car handles. It certainly isnt slammed and you're not really DDing the car so I'd say leave well enough alone.
As for your codes hopefully they were a fluke and will never appear again. I hate electrical issues, its always something stupid. If you did indeed have an issue with your TPS and MAP sensor, I'd imagine the car would idle funky. What does it read in evoscan? IIRC mine says I think 12.9%
As for the wideband are you only having issues logging it? Does it show the correct values from the gauge face? If so I'd venture a guess that its an issue with the formula in evoscan. Have you updated the software recently by chance?
Old Mar 19, 2013 | 11:45 AM
  #92
kyoo's Avatar
yeah - i forget what exactly, but i gave it a whirl and it looked normal.
Yeah it shows the correct values from the gauge, etc. It's only when in evoscan that it doesn't show up right - formula was modified for the autometer back in 2009 or something and unchanged since then - and even so, it should still be fluctuating etc., just the wrong number coming out right? right now it just stays pretty much stagnant at 10.xxx in evoscan - no other changes outside of this wideband moving from one car to another. just strange.. hopefully i figure it out sometime
Old Mar 19, 2013 | 12:31 PM
  #93
heel2toe's Avatar
Well if the formula is wrong it wouldnt necessarily have to fluctuate. What if the formula was something simple like *=10. The value would always be 10, right? Do you have it wired into the ecu or are you using a serial cable? Maybe you have an issue with a connection?
Old Mar 19, 2013 | 12:43 PM
  #94
kyoo's Avatar
def not that: formula i've been using for the past few years is:
10.00+(16.00-10.00)*x/204
so basically it's getting an x reading of almost 0 almost all the time
i'll have to ask the shop how the wideband was wired in... i think that might be the key there
Old Mar 19, 2013 | 12:51 PM
  #95
heel2toe's Avatar
Yeah well that would obvi be a silly equation I was just stating that for sake of discussion. If you know the formula hasnt changed then it must be an electrical/ mechanical issue, rather than a coding error.
When you used to log it, would you only need to hook up one USB cable to your computer aka your tactrix cable or was there another cable? If it was only one cable then it must be wired into your ecu.
I've been meaning to wire my wideband into my ecu but keep putting that off. I have a serial cable that was made years ago and just have that sitting in my glovebox. I think if you have it wired into your ecu though there is some code that needs to be flashed into your evu or additional XML files that need to be added to your laptop. I know there is a thread on it in the Ecuflash section that explains everything. Since I have yet to do it though I dont remember exactly what it entails.
Old Mar 19, 2013 | 01:11 PM
  #96
kyoo's Avatar
I think that's the issue here - it wasn't wired to the ECU!! another mystery solved.
Old Mar 19, 2013 | 01:49 PM
  #97
heel2toe's Avatar
Haha I'm a genius!!! Well, get err done!
And get to an auto-x already, Im dying to know how the Ohlins compare to your old Bilstein setup.
Old Mar 19, 2013 | 03:18 PM
  #98
kyoo's Avatar
we'll see how quickly i can get it done!
Old Mar 23, 2013 | 05:58 PM
  #99
kyoo's Avatar
Originally Posted by kyoo
Current Ride Height:
A little lower than I'd like at the moment, but I will adjust it later when I've got more time!
Taking a closer look at this (and checking in the garage) I think the ride height on the passenger side is actually a good bit higher than on the driver's side... def will need to get this corner balanced or something
Old Mar 24, 2013 | 11:52 AM
  #100
Uhuru's Avatar
Ohlins DFV
I see you have Dunlop Direzza tires, are they Sport Z1, or 03G?
Old Mar 24, 2013 | 12:33 PM
  #101
kyoo's Avatar
Originally Posted by Uhuru
Ohlins DFV
z1 star specs
Old Mar 24, 2013 | 03:59 PM
  #102
Uhuru's Avatar
z1 star specs
Are they any good on EVO IX, are you satisfied with them?
Old Mar 24, 2013 | 05:49 PM
  #103
kyoo's Avatar
they're dated as of this season now - the ZII's, rivals are out now
Old Mar 24, 2013 | 05:57 PM
  #104
MCPunk79's Avatar
How do you like your Ohlins? I've heard nothing but good things about both the ride quality and performance of them...
  #105
kyoo's Avatar
Anyway, the only issues for my car as it stands now are:
- P0069 Code keeps returning - this is the MAP sensor code. I've got an omni4 bar on the car that ran perfectly on my previous evo, so not sure what is causing the issue
- The O2 sensor needs to be wired to the ECU (not sure why it wasn't done in the first place), and the gauge position redone on the steering column
- Whiteline steering rack bushings installed
- There was a picture above of the exhaust that looks like the frame rail is dented - however, I went under the car the other day when I was doing the coilover protection, and it looks like those frame rails are shaped that way, not dented.
