Evo X turbo in a 2012 Ralliart
Old Oct 25, 2017 | 02:50 PM
Shifty12Ralliar's Avatar
Hey guys im new here im pretty sure this might have been asked alrrady but i was wondering if anyone knows or has a list everything i wpuld need to get to put an EvoX turbo in my 2012 ralliart
Old Oct 26, 2017 | 09:20 AM
LetsGetThisDone's Avatar
You'll probably get a better answer by posting here:
https://www.evolutionm.net/forums/09...rivetrain-309/
Old Oct 26, 2017 | 12:28 PM
RazorLab's Avatar
Search is your best friend. Well, obviously not, but it should be:
https://www.evolutionm.net/forums/09...arts-list.html
Originally Posted by EricJ@AMS
This is the list of everything needed to swap an Evo X turbo onto a Ralliart. If its not listed, the Ralliart has the same part # and can be reused on the new turbo setup. This list should be comprehensive and complete. Its even broken down into required and recommended pieces. Prices are list prices from Mitsubishi.
Required (a complete turbo assembly off an X should include all of this):
1515A183 (1515A198) Turbocharger 2,022.79
1555A476 Exhaust manifold 514.82
MN119784 Exhaust stud x2 (these will not come out of your Ralliart turbo without breaking) 9.73 x2
1515A150 Turbo Outlet pipe 62.20
1515A184 Turbo to manifold gasket 44.10
1555A289 Turbo to 02 housing gasket 40.37
1555A423 O2 housing 171.77
1225a155 Oil feed line 27.22
1225A181 Oil return line 75.97
1310A469 Coolant return pipe 12.10
1310A577 Coolant feed pipe 25.20
MF650114 coolant banjo bolt x2 7.37 x2
MF660065 coolant banjo bolt gasket x4 0.95 x4
1542A042 Inlet elbow 61.08
1515A053 Inlet elbow gasket 10.10
1570B095 Downpipe 304.52 (it would be cheaper just to get an AMS widemouth downpipe instead of stock Evo downpipe and O2 housing)
3078.50 + 27.22 +304.52 total list.
1055.71 + 27.22 + 304.52 without new OEM turbo
Recommended but not required to work:
1555A320 O2 housing bracket 19.08
MD194403 Oil return line gasket 1.53
1515A166 Compressor housing bracket 19.08
MF140264 Compressor housing bracket bolt 2.23
MF140260 Compressor housing bracket bolt 1.30
MR281085 Turbo outlet pipe gasket (same as Ralliart but new ones are recommended) 4.65
47.87 total list.
RussellM
Pacific Northwest
162
Nov 26, 2012 09:45 PM
YoshiBishi
Aug 28, 2012 07:17 AM
rsonistxl
Northeast Region
22
Apr 15, 2012 08:33 AM
