2003 Evo8
Old Jun 13, 2021 | 02:35 PM
  #46
kwag415's Avatar
She started up great! Like she was running yesterday didn't even need to crank. I put about a cap full of oil in the cylinders and turned it over by hand then I turned it over with the fuel pump relay disconnected. I then put the plugs back in and went to start and she turned over great lil smoke from the oil but I swapped the plugs after the smoke was gone and no smoke since I added a evo 9 BOV. I've since filled the take with good gas done 2 oilchanges one before the car ran and one after the car ran for a little bit ive put about 10 miles on the car just driving around the block not even a hiccup besides a transmission sound like marbles in a can that I found is comming from the driver side by the oil fill plug on the transmission ive been told the act hd/streetlite flywheel has made this kind of chatter or rattle for some people but it only happens when the car is warm and the clutch is out if I press the clutch in the sound goes away.. usually happens with the ac on as well around 1000-1100 and up rpms
SoundBoy4
Dec 29, 2011 08:14 AM
bumblebee04
12
Apr 3, 2011 02:46 AM
FishermanIvan
Northwest Region
Dec 17, 2008 04:06 PM
fireroasted
Oct 24, 2008 11:38 PM
EVO8.com
23
Dec 15, 2004 08:36 AM
