Cursedsms Official Build Thread
Old Sep 20, 2022 | 07:02 PM
CurseDSM's Avatar
Ok so this is my official build thread. Lets start with the car.
Bone stock 05 evo VIII rs with 18000 original miles
First build consisted of this stuff
Engine:
Standard rod 2.4
Manley turbo tuff rods
Weisco Hd 12.5:1 pistons Swain tech coated
Oem mitsu crank
rebuilt oil pump gears that are polished
Swain tech coated bearings
Cosworth hg
Torque solutions motor mounts
Head:
Force Engineering Nasty head port and polish
1mm over Ferrea competition intake valves standard size exhaust valves
Bronze magnesium valve guides
Kelford 288 hl cams from GSC S2
Aem true time cam gears
Performance Springs valve springs with Ferrea retainers
GSC Zero tick lifters
Sparttech non cdi cop
Turbo:
Map Ef4 that will be ported and polished up and clipped by Force Engineering
Map o2 housing with dump tube
Zeitronix Wideband 02 sensor
Map ported exhaust manifold
Intake:
Map rev3 Intake mani
Milspec 65mm throttle body
Bushur ic pipes
Ams Fmic
Fuel:
Fic 2150s
Magnus fuel rail
Redone double pumper controlled by the Haltech
Dual Walbro 2550s -8 Y into -10 to fuel rail
Magnus Afpr
Magnus in line fuel filter
Zeitronix eca flex fuel sensor
Engine Management
Haltech Elite 1500
Grimspeed 3 port ebc
This engine lasted about 5400 miles or so before I decided to go crazy. I got all the new parts for the new turbo build with this same motor and decided to go Ign-1a coils and totally destroyed the motor, turbo and as you all saw everything else. So with that said here is how the car sits today.
Engine
Slowmotion Motorsports 2.2
2.4 block with 97mm bore and o ringed
Custom stock modified head gasket
Manly turbo tuff 162mm rods
Manly Platinum Series pistons with skirts and tops coated by line2line coatings
Callies 94mm crank
Head
1mm over Ferrea competition intake valves standard size exhaust valves. Valves bottoms and bowls coated with heat barrier from line2line
Kelford 288 hl cams
Performance Springs 29.01 valve springs with Ferrea retainers
Haltech Ign-1a coils with MSD wires
Reversed cam angle sensor
Turbo
Forced Inductions s372 turbo
Fis .81 ar race cover
Intake port coated by line2line
Divided t4
PTP Lava cover
Tial MVS wastegates
Exhaust and Manifold
Jm Fabs divided t4 top mount with 1.5 runners
PTP lava wrapped
Jm Fabs 3" downpipe PTP lava wrapped
Buschur 3" exhaust
Intake
Jm Fabs billet race manifold
S90 74nn tb
Fmic
Ets 5" intercooler
Slowmotion 2.5" and 3" ic pipes
TIal Q 50mm bov
Fuel
ID 2600cc fuel injectors
Magnus fuel rail with -10 fittings
Magnus afpr
-10 feed line
-8 return line
Areomotive -10 fuel filter and 10 micron filter
Bulletproof racing double pumper with dual 525s
Trans and T case
RRT trans with all evo 8 guts with carbon synchros
RRT t case, Raif uses this t case in his race car. I really don't have any specifics but I know its bad ***.
Englewood 2 piece driveshaft, Chrome molly front, aluminum in the rear.
Act mod twin 225 with organic discs rated for 725 ft lbs of tq
For now axles are stock. Figured that would be easier to replace when I break stuff lol.
Brakes and Suspension
Enkei coilovers
Racing Brake 2 piece rotors both front and rear both drilled slots
Whiteline ball joints
Energy Suspension full bushing set
Electronics
Haltech Elite 1500 ecu
Haltech single channel wb
Haltech Ic-7 dash
3d Racing Solutions dash bezel
Zeitronics flex fuel sensor
Grimspeed 3 port boost controller
Braille battery
Aem 5 bar map sensor
Aem 150 psi pressure sensor for fuel pressure
I know all this stuff is in my signature and all but there is alot in this that I can't put in there lol. I will add some pics as I can find them again to add to this thread. Again I would like to thank all who followed my Evo update thread and hopefully this is a little better of a thread to read rather then the disappointing read in the other thread. Here are some pics that are of the new build.
Old Sep 20, 2022 | 07:03 PM
CurseDSM's Avatar
Old Sep 20, 2022 | 07:14 PM
Super excited for this build. Sub'd
Old Sep 20, 2022 | 07:28 PM
CurseDSM's Avatar
Well I know you have been really supportive in my other thread and its much appreciated. Unfortunately shootout is in a little over a week and I have enough time to break in the motor being it has 0 miles on it. Tuning it will be a few weeks till I can get some extra cash together. I am going through some more pics but I want different ones being I don't just want the same thread as the other one ya know. Goal is 1000 whp for all who are wondering but I think there is enough in this turbo to do close to 11 or 1200 depending on dyno.
Old Sep 20, 2022 | 08:09 PM
osetsky's Avatar
You have exactly how many Evos? What the shiiiiiiiit!??!?!
Old Sep 20, 2022 | 08:14 PM
CurseDSM's Avatar
I have 1 Evo?
Old Sep 21, 2022 | 10:33 AM
TimInselman's Avatar
Been a long road for ya.. but you finally get to enjoy it...
Old Sep 21, 2022 | 11:06 AM
RobbieOh's Avatar
5 Year Member
Rooting for that 1K + whp!!
Old Sep 21, 2022 | 05:56 PM
CurseDSM's Avatar
Thanks guys. I have the very first start up on video and kind of a walk around but says it doesn't support the video. I will send it to my computer and see if I can get it to work. Car sounds good but I have a noisey serpentine belt. I took it for a drive today and stock gauge is pegged but temp on Haltech says 180 to 193*. So idk what's going on. Not a whole lot of time to play with it.
Old Sep 22, 2022 | 05:19 PM
CurseDSM's Avatar
So if anyone has an idea how to change videos to make them work on here can you let me know. I would like to post the first idle but it doesn't like the video format.
Old Sep 22, 2022 | 05:55 PM
Seems like using YouTube is the most common platform
A standard Mpeg file is not working on an upload?
Old Sep 22, 2022 | 06:34 PM
CurseDSM's Avatar
Not from my phone. I sent it to myself and it's on windows media player now and it didn't like that either. Idk I'll figure it out lol. I'm so excited to show everyone lol.
Old Sep 22, 2022 | 06:47 PM
More than ready for some cam rumble. Dont be cheap w/the clip length LOL
Old Sep 23, 2022 | 01:31 AM
CurseDSM's Avatar
Lol trust me there is plenty of rumble. The clip is 25 seconds and I basically go around the car and stop in the back for a second and go back around . I will just have to play with the file to see if I can get it uploaded.
Old Sep 23, 2022 | 04:23 PM
Monster4's Avatar
5 Year Member
Handbrake is an easy to use transcoder for video files.
