AEM Twinfire CDI & Coil On Plug Setup Cheap!!
Old Jun 3, 2010 | 03:06 PM
AngryEvo8's Avatar
SOLD
So I bought this kit a little while ago thinking it would cure my ignition issues I was having. Car would break up on the dyno at high rpms. Turns out the problem was not ignition related at all (small mix of 93 & E70). Drained tank and filled it up with e70 and all the problems went away.
No need to have this setup yet. This is the cheapest cdi & cop setup you will find. Includes: AEM Twinfire cdi box, cdi bracket, Magnacore plug wires w/ 1g coils and coil packs, and wiring harness. Only $250+ shipping for everything.
Description: AEM’s digital multi-channel Twin-Fire Ignition is the lightest, smallest and most cost effective ignition module on the market. This unit is available in four- and eight-channel configurations, works with O.E.M. coil-on-plug and distributed spark systems, and is ideal for applications that utilize aftermarket stand-alone engine management systems.
Our Twin Fire Ignition module is the only capacitive discharge ignition system available with dual capacitors. This enables the Twin-Fire to produce more spark energy and voltage per spark than any other available capacitive discharge ignition unit. AEM’s exclusive Twin-Cap technology stores the energy for two distinct spark events and allows for full energy for each individual plug, including high-rpm V8s, and even on rotary engines utilizing separate leading and trailing ignition maps.
Works with coil-on plug and distributed spark systems
Exclusive Twin-Fire technology uses independently-firing twin capacitors to store energy independently for two distinct spark events
Twin-Cap spark events are at full energy and can be simultaneous
540v primary/54,000v secondary voltage energy
189mJ spark energy per capacitor
Multi-Strike capability of up to 10 sparks per ignition trigger (20 degrees)
Smallest (5.5” x 4.625” x 1.375”) and lightest (1.5lbs) CDI on the market
Four- or eight-channel availability
Full spark energy with battery voltage as low as 9v
Tachometer output included
Extruded enclosure
Pics:
Thanks
Old Jun 4, 2010 | 08:38 AM
AngryEvo8's Avatar
Bump for a good upgrade!
Old Jun 5, 2010 | 08:29 AM
AngryEvo8's Avatar
Bump it up!
Old Jun 5, 2010 | 03:40 PM
italianevo88's Avatar
bump for some better ignition!!
Old Jun 6, 2010 | 01:57 PM
AngryEvo8's Avatar
Bump.
Old Jun 7, 2010 | 02:15 PM
AngryEvo8's Avatar
ttt, I know someone needs there breakup to clear up!
Old Jun 8, 2010 | 07:50 AM
AngryEvo8's Avatar
Bump!
Old Jun 9, 2010 | 11:57 AM
AngryEvo8's Avatar
Bump.
NJ_evoIXgsr
Mar 9, 2017 05:57 PM
cficare68
May 13, 2016 09:42 AM
boostx
Apr 20, 2015 03:06 AM
SparkTech
33
Mar 21, 2012 06:47 AM
