Rotating Assembly - TI rods, high-comp pistons, 100mm crank
Old May 4, 2013 | 12:52 PM
EVOlutionary's Avatar
I have for sale a full rotating assembly for a 4G64 block. The pistons are 87.5mm so they will NOT work in a 4G63 block. The kit includes a used 100mm 7-bolt 4G64 crankshaft, custom Crower Titanium H-beam connecting rods and custom Wiseco high-compression pistons. Of course final compression is going to depend on your headgasket thickness as well as combustion chamber volume, but this kit should be in the 12 to 13:1 range and were intended to run on methanol, ethanol or E85. I would NOT recommend trying to run pump gas at any boost level, but I'm not a tuner, so you can do whatever your tuner recommends.
These parts came out of an assembled, never fired, never ran short black that sat for quite a while. If I were going to use this kit I would re-polish the crank and a couple of the pistons. Brand new full set of rings straight from Wiseco is included.
$3000 shipped
Specs are as follows:
Crank:
- OEM Mitsubishi 4G64 100mm 2.4L crankshaft
- bearing surfaces should be polished.
Rods:
- Crower Titanium H-beam, P/N T93970B-HBEAM
- 406 grams with bolts
- 6.324 inch length (160.63mm)
Pistons:
- Wiseco 87.5mm, P/N CA-97515-7891
- CH 25.04mm
- dish = -7mm
- 299gm with top two rings
- DLC coated tool steel wrist pins, 90gm
Old May 21, 2013 | 07:43 PM
Bump, make an offer. Need this GONE!
Old Jun 11, 2013 | 09:02 PM
bump - buy this and be cool and fast.
Old Jul 2, 2013 | 08:23 PM
$2500 shipped. Had some interest but no buyer yet. I have the piston build specs to potential buyers.
Old Jul 3, 2013 | 01:59 PM
hubz91talontsi's Avatar
How much for just the rods?
Old Jul 3, 2013 | 08:13 PM
If I part it out prices shipped are as followed. Picked up I'll deduct $30:
Rods - $2000 (~$3000 to have a set built)
Pistons - $500 (~$1000 to have a set built)
100mm 4G64 crank - $175
Old Jul 19, 2013 | 08:13 AM
Still for sale!
Old Aug 3, 2013 | 05:47 PM
Make an offer. Worst I can say is no thanks. Need these gone - just bought a new house and need downpayment $$ and don't want to move all this stuff to the new place. . .
Old Jun 28, 2014 | 11:23 AM
Pistons $250 shipped. Crank sold. Keeping the rods for a future build.
Old Aug 4, 2015 | 03:33 PM
Bump - still have the rods and pistons for sale. I believe the rods can either be used in a 4G64 block with a 100mm crank, or with a 4G63 block and stock (88mm) crank.
I can bring them to the shootout if you want to buy them in person.
Old Jul 27, 2016 | 10:31 PM
Benja258's Avatar
Rods still for sell.?
EVOlutionary
May 13, 2019 09:34 PM
EVOlutionary
Oct 15, 2017 04:11 PM
EVOlutionary
Mar 3, 2017 01:00 PM
EVOlutionary
Jul 3, 2016 09:09 AM
