Built engine (testing waters)
Old Sep 23, 2013 | 08:47 AM
evolve_VIII's Avatar
I recently swapped a 2.4 into my car and I still have my stock 2.0 4G63 block. I was going to build a back up engine, but I dont want it to sit around and collect dust.
I would rather have a customer select what crank, rods, pistons, bearings and other components to install before I do a build. This way they can choose what parts they want in it, what compression ratio they want for fuel use, and stroke. Also, will need to know what the power goals are and boost to set the ring gaps and PTW accordingly.
It will be a complete short block. I can do a complete long block as well but the price will go up.
There will not be a core charge.
With the block work, wiseco 1400HD, Manley H-beams, bearings, crank, oil pump, oil pan, pick up tube, oil scraper, oil filter housing, it will be around $2,500 + shipping. The price will go up for manley turbo tuff rods, aftermarket crank, etc...
The build will be documented and blue printed so you knwo what you are getting.
PM me if you have any questions or are interested.
Old Sep 23, 2013 | 02:19 PM
Howulikemyevo's Avatar
What compression would be good for dual map on e85 and pump gas on a 2.4L manley tt ibeam?
Old Sep 23, 2013 | 05:35 PM
N33d4sp33d's Avatar
any way possible to do a 2.4LR longblock.....PM me if possible with price shipped, are you a master tech
Old Sep 24, 2013 | 06:27 AM
maknuge's Avatar
he has a 4g63 to build, not a 4g64. 2.4L is not an option from a 4g63
Old Sep 24, 2013 | 06:51 AM
It can only be made into a 2.3L using the 4G64 crank.
9.5:1 would be ideal.
If you plan on running on e-85 most of the time, you can go to 10:1 and run low boost on your 91 map.
Old Sep 25, 2013 | 06:18 PM
thaoski_taicho's Avatar
So are the parts not yet in the motor? I'd be very interested in the short block. Let me know My number is 7152520962 texting is most ideal.
EvolutionIXMR06
May 18, 2014 05:26 AM
PRS
Evo 'For Sale' Engine Internals and Drivetrain
35
Dec 19, 2013 10:24 AM
MRfabolous
20
Sep 13, 2012 08:33 PM
dsevo
218
Feb 12, 2010 10:25 AM
SBR INC
24
Oct 19, 2009 09:37 AM
