275 35R18 Slick on NT03 10.5 stock body Evo
Old Apr 23, 2016 | 10:31 AM
  #256
you guys are implying narrow car > more mechanical grip?
All the race cars I see are pretty wide.
Old Apr 23, 2016 | 01:03 PM
  #257
Inching towards getting wheels on and working out fitment. Ordered 275x35x18 Nitto NT01s. Progress pics
Pressed everyhing out
Pressed everything in.
Racingbrake SS pistons
Ohlins DVF with 12k 14k Swift springs, Ciro caster plates.
WL trailing arm bushings, rear bump steer, tie rods for front roll center
Cleaned up some of the extra/rough aluminum from manufacturing.
Old Apr 23, 2016 | 03:30 PM
  #258
Oooh, yeah, gotcha. With the other rear trailing arms. I'd like to, but those are outta my price range at this time.
Report back how the SS pistons work for you. I'm seeing posts where people have been experiencing fluid leaks. I don't think anyone has figured out why.
Any particular reason for the spring rates?
Old Apr 23, 2016 | 03:55 PM
  #259
No im going to use the stock arms and shave em a lil if i need to. Research informed me they are good rates for track only car. Maybe even 14/16. Rather have more spring than more sway bar.
The SS pistons I've been told will leak when sitting while weather is really cold. I should have a heater in my garage before winter so hopefully this wont be a problem.
Old Apr 23, 2016 | 05:58 PM
  #260
Heated garage? Spoil-t 😛
If you can get everything to fit, please let me know. I'd rather NOT cut body panels. Not that I'm looking forward to selling my new wheels and tires to buy more new wheels and tires LOL .
Old Apr 23, 2016 | 06:29 PM
  #261
Nah, I am in Chicago. Diff ballgame than Fresno. Gets below 0 here.
Old Apr 23, 2016 | 07:02 PM
  #262
LOL. Even in winter here, my garage is never below like 55.
Old Apr 24, 2016 | 01:35 PM
  #263
RJones's Avatar
Originally Posted by kaj
you guys are implying narrow car > more mechanical grip? All the race cars I see are pretty wide.
I'm thinking with my autox brain. Narrower car is easier to get through a course.
Old Apr 25, 2016 | 12:36 AM
  #264
Makes sense. I never realized how drastically different cars setups are between AX and road racing until I got involved in both.
Old Apr 26, 2016 | 11:10 AM
  #265
I should probably just start a build thread. Tires arrived.
Old Apr 26, 2016 | 11:50 AM
  #266
RJones's Avatar
Yeah I used to try to target sort of a "best of both worlds" approach for my build, but I realized more and more that as you try to become more competitive in either world, that doesn't really work. Now it's definitely a purpose built autox car and there are several parts I'd have to swap out if I wanted to take it to the track.
Old Apr 26, 2016 | 12:52 PM
  #267
Same here, So I focused on road courses. The car started out doing really well at autocross, but as it becomes more track focused it has suffered a bit in the parking lots LOL.
Old Apr 26, 2016 | 12:55 PM
  #268
Construct's Avatar
What's on your list of parts you'd swap over for track duty?
Aside from tires, the only changes I make to my STU build for track-type use are brake pads and setting the rear sway bar to full soft instead of full stiff. My current tail-happy setup is fun at 60MPH on an autocross course, but terrifying at higher speeds on a road course.
Old Apr 26, 2016 | 02:30 PM
  #269
RJones's Avatar
I have an SM car. My rotors are not track suitable (not enough mass to deal with the heat), I have a half radiator, which probably won't allow the cooling system to hold up to track heat, the wing will create way too much downforce at track speeds for the front aero to keep up with, the car is fast enough that it should have rollover protection, the suspension setup would probably be too loose at track speeds, etc etc. The last time I tracked it was in 2011 when it was 2.3L stock turbo, and making about 370whp on e85 at about 200lb heavier than it sits now.
Old Apr 26, 2016 | 07:56 PM
  #270
60mph? Nice! I've done that on ONE of our courses. Must be nice. LOL
What in Heck are you running for brake rotors?
