Old Oct 2, 2016 | 01:11 AM
  #1861
CrAnSwIcK's Avatar
Holy ****, that was fast...I know ****'s not holy, but man that was quick...
Old Oct 2, 2016 | 01:50 PM
  #1862
truthdweller's Avatar
Veteran: Navy
Probably because Whiteline has a distributor in Texas...even then, yes, that was quick. Here's the tracking for it:
Old Oct 2, 2016 | 02:18 PM
  #1863
Veteran: Navy
I lubed up the nuts with PB Blaster this morning, and will be taking the Control Arms off tomorrow morning over at the bro-in-law's house. Pep Boys should be able to press out the old, and in with the new, back to reinstall, then return to align. Should save some money.
Old Oct 3, 2016 | 02:07 PM
  #1864
Veteran: Navy
Okay, here are the polyurethane bushings pressed in to the rear, lower control arm's outside position:
The other bushing in the package has a slightly smaller diameter, but will NOT replace the inner bushing for it is the wrong diameter:
Old Oct 3, 2016 | 02:12 PM
  #1865
Veteran: Navy
"Fadi," the guy at Pep Boys whom I trust to touch my car, was off today, so tomorrow I'll have it aligned.
Old Oct 3, 2016 | 03:05 PM
  #1866
SilentCool's Avatar
Nice upgrade! Would these bushings last the life of the car or just much longer than the other OEM-like stuff?
Old Oct 3, 2016 | 04:37 PM
  #1867
Veteran: Navy
Originally Posted by SilentCool
Nice upgrade!
Don't know if it's an upgrade so much, as it is a replacement for a broken part, lol! I went with polyurethane because, as you know, I'm beating it up on a track now and then, and the OEM rubber bushings wouldn't last, nor would they provide the support for the crazy G's I'm putting on the car.
This is my first rodeo with Polyurethane too, so that's yet to be determined. Speaking of PU, the filling that you provided to me to fill my rear motor mount, is rock solid so far as I can tell. I've inspected it with a mirror a few times and it appears to be staying in the mount and not breaking apart, and it's been a good while since I did that!
Old Oct 3, 2016 | 05:50 PM
  #1868
CrAnSwIcK's Avatar
Gary, could you contact whiteline and let them know...cause I'm pretty sure the usdm 2.0L lancers have the same control arms.
Old Oct 3, 2016 | 06:02 PM
  #1869
Veteran: Navy
Thumbs down
I inadvertently ordered a control arm with those bushings and it should arrive soon. Im going to retake measurements and then contact them. I was told they would fit both inner and outer, but from what I'm getting, the inner bushing is too big. I'll let you know...
Old Oct 4, 2016 | 06:35 PM
  #1870
Veteran: Navy
Change of plans...I "refused delivery"on the Control Arm to avoid having to pay shipping to return it on an RMA. So, I didn't get repeat measurements on the inner bushing. I'll call Whiteline and let them know what I found.
Garrett, just confirming that the 2004-2006 Lancer Ralliart Sedan uses the same control arm configuration as the same year Sportback/Wagon?
Old Oct 4, 2016 | 08:41 PM
  #1871
CrAnSwIcK's Avatar
I'm deployed at the moment, so I don't have my computer.
Old Oct 11, 2016 | 08:18 PM
  #1872
Veteran: Navy
Deleted
Old Oct 11, 2016 | 08:36 PM
  #1873
Veteran: Navy
Been communicating with Whiteline and after looking at their bushing sizing chart (below), I hope I've found a match. The dimensions for my inner bushing, for the rear lower control arm are ~, OD = 35.50 mm x ID = 19mm x L = 50.8 mm. A Whiteline USA distributor will be sending the bushings (W62535) FOC, Free Of Charge, by the end of the month:
http://www.whiteline.com.au/product_...es&catsize=yes
Old Oct 17, 2016 | 05:45 PM
  #1874
Veteran: Navy
Im FINALLY all SS from turbo to tailpipe!
Old Oct 21, 2016 | 03:15 PM
  #1875
CrAnSwIcK's Avatar
looks great Gary, been wanting to go 2.5" cat-back for a while now...not stainless though, cause I'm cheap...but I think I'll fab something up.
