EcuFlash Definition File Master List
Old Mar 25, 2008 | 02:19 PM
senate6268's Avatar
I realized today that I probably have the largest collection of Lancer definition files for EcuFlash. I've made definition files for all the users in the original EcuFlash thread (shoutout to Z_Lancer_man!!) when there weren't any for them to use to view their ROMs. So here's a file containing all the definition files I have. This thread should be a starting point for anyone using EcuFlash with their Lancer. Most will find the definition file they need here.
***These definition files only work with the newest versions of EcuFlash***
Extract the files inside to c:\program files\openecu\ecuflash\rommetdata\mitsubishi\lance r. This location is where the definition files reside for EcuFlash.
Here are the definition files included:
81870006 - 2003 LS, AT
81870015 - 2003 ES, AT
81900006 - 2003 OZ, MT
81900015 - 2003 ES, AT
81900016 - 2003 ES, AT
86640007 - 2005 ES, AT
86640015 - 2005 ES, MT
87260006 - 2003 OZ, MT
88250013 - 2006 ES, MT
88540011 - 2002 ??, AT
88560010 - 2002 ES, AT
88560019 - 2002 ES, AT
91890006 - 2003 OZ, MT
91890008 - 2003 ??, ??
91890014 - 2003 OZ, MT
91890015 - 2003 OZ, MT
92290022 - 2004 OZ, MT
97250005 - 2002 OZ, MT
96630008 - 2005 ES, MT
98670010 - 2002 OZ, MT
98720009 - 2002 OZ, MT
98720010 - 2002 OZ, MT
98720012 - 2002 OZ, MT
98720018 - 2002 OZ, MT
98720020 - 2002 ES, MT
Enjoy!!
- Pete T.
UPDATE... (07-18-2008)
Added all definition files into a single ZIP file. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
UPDATE... (11-11-2008)
Added definition file for 2003 LS, AT to zip file. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
UPDATE... (12-02-2008)
Made modifications to definition file 81870006. Corrected MAF Scaling and MAF Smoothing Table Y-Axis values.
UPDATE... (08-03-2009)
Corrected definition file for 98720012 and updated zip file.
UPDATE... (08-16-2009)
Corrected definition file for 86640007 and updated zip file.
UPDATE... (08-18-2009)
Added definition file for 2002 ES - 88560019. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
UPDATE... (08-30-2009)
All definition files have been updated so that they now only work with the newest versions of EcuFlash. These definition files will NOT work with v1.29a or prior. Please update EcuFlash to the newest version available to use these definition files.
UPDATE... (09-12-2009)
Corrected definition file for 2003 ES AT - 81900015. Corrected improper hex value for internal ID in 81900006 definition file.
UPDATE... (02-06-2010)
Added definition file for 2005 ES - 86640015. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
UPDATE... (02-13-2010)
Added definition file for 2002 OZ AT - 88560021. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
UPDATE... (07-13-2010)
Added definition file for 96630008 - 2005 ES, MT. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
UPDATE... (08-06-2010)
Added definition file for 98670010 - 2002 OZ, MT. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
UPDATE... (08-14-2010)
Added definition file for 91890008 - 2003 ??, ??. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
Old Mar 27, 2008 | 09:28 PM
senate6268's Avatar
Reserved
Old Mar 28, 2008 | 03:39 PM
ihearthondas's Avatar
Sweet! I'll try it out later tonight. Thanks bro!
Old Apr 7, 2008 | 10:36 AM
senate6268's Avatar
removed...
Old Apr 22, 2008 | 03:22 PM
darkmitsu's Avatar
hey senate i am hosting that file for the older version of ecuflash i figured it would be good to add here... http://www.box.net/shared/4fxrdljwgk
Old May 4, 2008 | 09:27 PM
andymige's Avatar
help me with defs. my car is a AT lancer es 4g94 2.0 liter 2005.
86640007
Old May 5, 2008 | 12:04 PM
senate6268's Avatar
86640007
I need a copy of your ROM file to do so. PM me.
Old May 5, 2008 | 12:24 PM
darkmitsu's Avatar
here is his file ...
http://www.box.net/shared/qwuu2e9csk
i can host the xml file for decoding once you post it up...
Old May 5, 2008 | 12:56 PM
senate6268's Avatar
I don't think this is a USDM ROM. So I won't be able to properly decode it.
Old May 5, 2008 | 04:29 PM
darkmitsu's Avatar
yeah i thought it was quite wierd that is was 512kb in size... if its a 4g94 engine you might be able to reflash your ecu with a different year model, that way you can change values... i flashed my brother 03 oz rom to my 02 es to test it and it works fine....
Old May 6, 2008 | 12:58 AM
andymige's Avatar
Ok
Old May 23, 2008 | 08:55 PM
andymige's Avatar
darkmitsu
you can send a rom at 03 04
I can use pm..
Old May 30, 2008 | 07:22 PM
darkmitsu's Avatar
http://www.box.net/shared/9d9v5af8ks
that link has a copy of my stock rom file. its 98720020 , i have flashed this to both my brothers oz and also tried taking his 03 oz file and flashing it to my ecu it works fine... i dont know for sure what it will do flashing it to yours because yours is not an american ecu, just be sure to copy your original file and save it to your computer, so you can flash your original back in case it doesnt work...
Old Jun 5, 2008 | 08:18 AM
TouringBubble's Avatar
81900015 - 2003 OZ, AT
91890006 - 2003 ??, MT
- Pete T.
Can I assume that the naming conventions are the same as the Evo ROMs? For instance, is 81900016 the latest revision of 8190XXXX and can be flashed to any 8190XXXX ECU?
With all the patches out for the Evo ROMs, we are making a move to just update the most recent ROM for a certain car/ECU just to keep things simple. It might be a good idea to do the same for the Lancer ROMs.
Old Jun 8, 2008 | 11:02 AM
senate6268's Avatar
Considering there are zero patches available for our ROMs I don't think this will be an issue. Nobody cares enough about our cars to modify the ROMs to our favor. We aren't cool enough to drive Evos...
