EcuFlash Definition File Master List
Old Oct 20, 2008 | 05:39 PM
  #61
senate6268's Avatar
Originally Posted by lilazn64
I think I found it. 98720009 seems to work for me. But how do I change the Load values? I got RPMs to view correctly using endian value, but Load is still funky
Use v1.29a. You can get it here:
http://freon.shackspace.com/car/ecu%..._setup129a.exe
Old Oct 21, 2008 | 05:39 AM
  #62
lilazn64's Avatar
awesome! fixed my problem! thanks!
Old Oct 22, 2008 | 06:32 AM
  #63
nestoledo's Avatar
hey, i still try it, somebody can help me with my definition, i can not found it.
File Type: zip
Old Nov 10, 2008 | 08:53 AM
  #64
4g94T's Avatar
can anyone help me out with my definition file?
http://www.box.net/shared/b9d3bzc920
Old Nov 11, 2008 | 07:00 PM
  #65
4g94T's Avatar
bump! anyone? where are the ecuflash gurus? I really need to tune my car
Old Nov 12, 2008 | 01:08 AM
  #66
4g94T's Avatar
thanks pete! master list updated.
Old Dec 2, 2008 | 07:42 PM
  #67
senate6268's Avatar
Tiny update to master definition list...
Cheers!
Old Dec 2, 2008 | 08:16 PM
  #68
4g94T's Avatar
Cheers!
Thanks!!!!!!!!
Can't wait to try it out =]
Old Dec 19, 2008 | 10:41 AM
  #69
TouringBubble's Avatar
Can Amby make this a sticky? I think it's warranted.
Old Jan 18, 2009 | 09:13 PM
  #70
janlin's Avatar
Definition file for Lancer 1.6 Sohc
Hi
Can you help me with a definition file for a Lancer 1.6 Sohc 2000 model year Asia spec car enclosing the Romfile out of the Ecu.
Thanks
File Type: zip
Old Jan 19, 2009 | 07:11 PM
  #71
andymige's Avatar
[02:26:49.247] sending init sequence 1 (0003)
[02:26:50.368] got 0x05 response
[02:26:50.368] sending init sequence 2
[02:26:50.378] got 0x1B response
[02:26:50.428] sending init sequence 3
[02:26:50.899] entering bootloader
[02:26:50.929] sending kernel size (3424)
[02:26:50.969] sending kernel load address (0xFFFF6000)
[02:26:51.029] uploading kernel
[02:26:51.600] verifying kernel checksum response
[02:26:51.610] kernel valid
[02:26:52.201] kernel get version
[02:26:52.221] rkrv: preamble 1 error
I have a problem when write up a different rom?
86640007 to 98720020
Old Jan 19, 2009 | 07:27 PM
  #72
senate6268's Avatar
For starters if you attempt to flash to a different revision of your ROM you risk bricking it. My guess is that EcuFlash doesn't have the correct communication sequence for your car. This means that EcuFlash is not compatible with your vehicle. See the following list for compatible vehicles:
http://openecu.org/index.php?title=E...VehicleSupport
Old Jan 19, 2009 | 08:14 PM
  #73
andymige's Avatar
but, i test write to ecu with (86640007Origina) and the test is complete
when I try on the test 98720020 then appear the preamble
Old Jan 19, 2009 | 10:13 PM
  #74
senate6268's Avatar
If you read what I wrote you will have your answer. You cannot flash any other ROM into your ECU other than 86640007. Your ECU can only have 8664007 or possibly another revision of that series.
Old Jan 27, 2009 | 11:53 AM
  #75
Exactly ... you can only flash 866400XX ROMs. A ROM with a higher number in the last 2 digits is a revision. If the first 4 digits are different, the car will likely not run.
