EcuFlash Definition File Master List
Old Aug 12, 2008 | 04:29 PM
  #46
senate6268's Avatar
Originally Posted by nestoledo
Somebody has the definition for a lancer oz 2004, this it is my rom
The ROM ID is 91210001 for this file. However, I don't have a working def file for it. One will need to be created from scratch.
Old Aug 12, 2008 | 05:44 PM
  #47
ThunderOZ's Avatar
so should I see anything? Like different things that can be modified like the sample evo rom on the how to use ecuflash thread?
Old Aug 17, 2008 | 06:17 PM
  #48
impetus19's Avatar
i was able to get the 81900006 to work..
I just had to tweak the file that i found online.
Do you still need it?
Old Aug 17, 2008 | 06:33 PM
  #49
ThunderOZ's Avatar
Yes please
Old Aug 17, 2008 | 06:58 PM
  #50
impetus19's Avatar
Here it is.
File Type: zip
Old Aug 18, 2008 | 03:25 PM
  #51
senate6268's Avatar
Not sure why you would modify the 81900006 definition file, which is for the 2003 OZ 5-speed. His ROM is the 88560021 as indicated by the ECU ID...
Old Aug 20, 2008 | 08:37 AM
  #52
ThunderOZ's Avatar
So what do I need to do then?
Old Aug 24, 2008 | 11:41 PM
  #53
ThunderOZ's Avatar
Ok so I just noticed something when I changed my hood... Under it there's a sticker and it actually has the ROM ID printed on it as 885621... Anyone else notice this?
Old Aug 25, 2008 | 07:32 AM
  #54
senate6268's Avatar
This is from when you went into the dealer for the ECU recall and they reflashed it. The sticker contains the TSB info and your ROMs ID.
Old Sep 6, 2008 | 01:54 PM
  #55
ThunderOZ's Avatar
Ok if I made a mistake and assigned a different rom id how do I change it?
Old Sep 8, 2008 | 07:14 PM
  #56
Lusion's Avatar
Could I get assistance with a 2001 Mirage ROM File? Thanks
http://www.box.net/shared/46n1epekit
Old Sep 12, 2008 | 04:13 PM
  #57
Lusion's Avatar
any help?
Old Sep 13, 2008 | 06:46 PM
  #58
ThunderOZ's Avatar
Ok I finally got mine to work.
ROM ID is 88560021
Car is 2002 Lancer OZ AT but shows as a ES 5MT
Old Oct 15, 2008 | 08:28 PM
  #59
lilazn64's Avatar
Hey Senate, what can you do for me?
http://www.box.net/shared/sr82kclsti
Old Oct 16, 2008 | 05:52 AM
  #60
lilazn64's Avatar
I think I found it. 98720009 seems to work for me. But how do I change the Load values? I got RPMs to view correctly using endian value, but Load is still funky
