corner balancing - adjust preload or shock length?
Old Jun 25, 2017, 08:50 AM
mrfred's Avatar
I'm reading up on corner balancing, and one thing that isn't clear is the preferred way to adjust the cross corner weights. I haven't found any mention of it in any of the articles that I've found. I have Ohlins R&T, so I could do either preload or shock length. My general feeling is that shock length is preferred so that as target cross corner weight is approach, wheel travel should equalize as well.
Old Jun 25, 2017, 09:23 AM
Yeah, read the same thing. I always thought it was strictly ride height adjustments. Changing pre-load, to me, affects compression / rebound & would be concerned about a corner to corner imbalance.
Its, no doubt to me, art & science combined. Dont know what you track involvement is, but corner balancing is only for those at the higher end of track work IMHO
Old Jun 25, 2017, 10:02 AM
mrfred's Avatar
I don't track it, but I like to tinker with things like this.
Old Jun 25, 2017, 02:08 PM
That's a lot of toil / labor if the EvO is not going to the track.
Have you seen a corner balanced car? You can likely see significant fender gaps diff from Left to Right
Anyway, I can appreciate your interest in wanting to know more about the process
Old Jun 25, 2017, 04:03 PM
mrfred's Avatar
Not sure I'm going to do it... just investigating. Yep on the fender gaps. I already surmised that evening out the fender gaps by shock length or preload will make the corner balance worse.
Old Jun 26, 2017, 11:27 AM
EVOizmm's Avatar
not always true. On something like a FWD Civic, yes those can get tricky to CW and might have a slight fender gap difference. But most evos I've done are pretty dang close (within 1/4inch at most).
Its really not a lot of work to CW a car unless it has some rusted coilovers that don't spin very easy.
Old Jun 26, 2017, 11:32 AM
Thanks Andy. Thats good to know
MRfred doesnt even track the car so I was mainly expressing my opinion as to why do the CW if its just a streeter
Joe
Old Jun 26, 2017, 11:34 AM
EVOizmm's Avatar
I typically do not adjust the preload to get CW set.
If you installed the coilovers with each one measured to match the opposite side, then you really wont be adjusting the ride height that much at each corner.
Old Jun 26, 2017, 11:35 AM
EVOizmm's Avatar
Joe
right, but then the questions an keep going. Why have more power? why have better suspension? why not just buy a Prius?
Old Jun 26, 2017, 11:38 AM
kyoo's Avatar
shock heights are ideal as I understand it.
that said, it shouldn't "matter" if the spring is always compressed more than what you add preload for. this is probably the case in the front but not always in the rear (if you lift the rear). i.e., you can add 1/2" of preload but if the spring is always compressed 2" then does it matter? the front's never going to come off the ground while racing.
Old Jun 26, 2017, 11:48 AM
EVOizmm's Avatar
try it. haha
I'd recommend running no preload. you remove the droop travel and like you said, will start lifting a wheel.
put just enough preload on the spring to hold it in place. then do all adjusting with the lower (moving entire shock body up/down).
Old Jun 26, 2017, 11:54 AM
Typically, to get good CB on the evo, the passenger front, and driver rear coilovers need to be a few turns longer. You don't use preload for corner balancing. Preload isn't really something I've seen the need to use on the Evo. It's usually used to attain ride height when you want to run a softer spring, but most coilovers are ride height adjustable.
Old Jun 26, 2017, 12:11 PM
Power & some suspension upgrades you can feel on the street. CB you can not (unless youre on the track)
Ive seen you drive Andy. Maybe you could feel the CB on the street
I & most here could not
Old Jun 26, 2017, 12:27 PM
EVOizmm's Avatar
you're right, you probably wont "feel" it unless you are extremely off.
just get ride height even on all 4 corners and I bet you'll be within a few % cross weight.
Old Jun 26, 2017, 01:08 PM
I get a CB and alignment at the same time when a new setup goes on. So it's hard to say what I "feel" because the car just got new coilovers, new alignment, and corner balance.
Quick Reply: corner balancing - adjust preload or shock length?
