ARP flywheel bolts question.
Old Jan 16, 2018, 10:46 PM
babaz7's Avatar
I'm doing a clutch job..installing a xtreme twin carbon clutch in my evo 8, I'm planning to use the ARP flywheel bolts on it.
What I want to know is..should i use locktite on the bolts or the ARP supplied lubricant?
And with the ARP flywheel bolts the torque is still 99 ft pounds at the flywheel?
Old Jan 17, 2018, 05:33 AM
Ayoustin's Avatar
According to ARP's instructions on their site, loctlte is to be used on the threads and the lube is put underneath the head of the bolt.
The torque spec is on the instruction sheet for the kit as well.
Don't put too much lube underneath the head, too much will cause it to get slung out and will end up on the clutch.
Old Jan 17, 2018, 09:08 AM
Received 1,544 Likes on 1,323 Posts
If you open the package, there are instructions under the lube packet...
But, as ayoustin said, red Loctite on the threads, a bit of lube under the head of the bolt, and IIRC the torque is 90 or 95ftlbs. Make sure the threads in the crank are clean.
Old Jan 17, 2018, 09:11 AM
heel2toe's Avatar
Are those puppies reusable? Im sick or ordering new flywheel bolts everytime I need a clutch. Seems like the only reason to opt for ARPs if so...
Old Jan 17, 2018, 09:17 AM
The OEM bolts are reusable...lol
Old Jan 17, 2018, 09:30 AM
heel2toe's Avatar
Since when!? I was always told to replace them...so whats the point to ARP flywheel bolts anyway?
Old Jan 17, 2018, 09:36 AM
kikiturbo's Avatar
fly bolts is one of those cheap insurances where if you reuse an old bolt and it fails it will cost $$$$$
Old Jan 17, 2018, 10:40 AM
Ayoustin's Avatar
I've always used blue loctite on flywheels bolts (242). I hardly ever use red because it's a **** to loosen bolts with that stuff on it, often times requires heat.
Most OE flywheel bolts are reusable but the ARP ones aren't that expensive and it's just one of those places I don't try to save a few bucks if it can potentially put the engine at risk.
Old Jan 17, 2018, 04:55 PM
hutch959's Avatar
flywheel bolts are not "torque to yield".. they are reusable.
the arp ones are reusable also.
do not put the lube on the threads, only on the bottom face of the bolt head (the part that meets up to the flywheel).
use loctite blue
rubio2325
Apr 24, 2012 03:04 PM
ninekrevs
Oct 26, 2010 01:15 PM
jmtx86
May 19, 2009 01:32 PM
DIDYSIS
Oct 19, 2008 11:19 AM
joeymia
Jul 22, 2006 11:20 AM
Quick Reply: ARP flywheel bolts question.
