5$ **** fitting ruined my entire block....
Old May 20, 2019, 07:48 PM
joey pierce's Avatar
Map performance evo 9 feed line to head adapter is **** lom tried to temove it after it broke and cracked my block lol
What the **** do i do???
Old May 20, 2019, 07:57 PM
Ive read that cast iron can be TIG welded (its not easy but has been done). In this case, the crack is very slight.
Maybe that cracked hole can be filled w/weld & tapped?
Just a thought / Let us know how this progresses as you look into
Old May 20, 2019, 07:58 PM
How tight did you get that poor thing?
If the block is cracked you're not left with a lot of options. Try JB weld or actually TIG welding it are about all you can do. The way it's cracked there will be hard to make it not leak.
Old May 20, 2019, 09:10 PM
Crack
It looks like its just the edge of the housing. Not the the block cracked through. And i can just weld this hole closed and run my oil feed to the head from a sandwhich plate?
Old May 20, 2019, 09:18 PM
You should not use a sandwich plate, the oil filter is low enough and semi prone to being knocked off as it is. You can run it from one of the ports on the OFH.
Abacus (May 21, 2019)
Old May 20, 2019, 09:26 PM
Ofh? And only reason no to from the sandwhich plate is that it could be knocked off?
Old May 20, 2019, 10:14 PM
Oil filter housing. There's two 3/8" BSPT ports that are plugged that you could use to feed the Mivec (just remove the plug, then get the adapter fitting to 4an from STM). No need to use a sandwich plate. Yes, it being knocked off is the "only" reason, but it's kind of a big one.
Old May 21, 2019, 07:48 AM
huzzle101's Avatar
I ran my oil pressure off a sandwich plate for a few months but im not that low to the ground i plan to lower my car so i have recently moved to the oil filter housing.
Old May 21, 2019, 08:49 AM
240Z TwinTurbo's Avatar
Did it crack because you used a tapered ezout when trying to remove?
Old May 21, 2019, 09:29 AM
Yep
Yes^^ but its only the bolt housing.
Old May 21, 2019, 10:18 PM
KingTal0n's Avatar
sorry I've never seen one of these engines. What is this port for, does someone wish to more fully explain the context of these modifications, implications,
for if so I would be in your debt, no question
Old May 22, 2019, 05:01 AM
Just a oil feed hole..
Old May 22, 2019, 06:32 AM
KingTal0n's Avatar
Yes but there is more to it than that. Somebody above said something about mivec oil supply etc... Where does this hole normally used for, why was it re-purposed, what are the other options,
what sort of hole is it, looks like a threaded hole in the casting of a block (strange) is the block aluminum? Those sort of holes frequently seem like they would strip or be annoying
Old May 22, 2019, 06:47 AM
kikiturbo's Avatar
is is a hole that is used for oil low pressure switch on older models and IIRC it has a NPT thread. On Evo 9 it is used to feed oil to the mivec variable cam control in the head and that used straight metric thread, in larger size. Block is cast iron. I will presume that the overtightened NPT managed to crack the block.
Problem is, to weld this up properly you need to take engine out and strip it to bits.. in order to clean it porperly.. It can be welded or TIG brazed. In any case I would convert it to straight thread as not to put in any additional stress into it after welding/brazng.
Old May 22, 2019, 08:22 AM
Biggiesacks's Avatar
the real problem with cracks is they are bigger then what you can see and they keep growing. You really have to grind them out completely and weld it back up to fix the problem.
