Mitsu & Subie Showdown Oct 30th 2009
alrighty... refreshed the bottom end w/ new ARP rod bolts and new rod bearings (apparently cylinder 4 was toast). Thank God we found it before something bad happened. My shep tranny was rebuilt by Inline and new HKS twin disc installed. Couple more stuff and im ready to be re-tuned on Friday. If all goes well and no "kaboom" i'll see you guys next week at HRP!
-Tom
-Tom
-Tom
-Tom
-Tom
-Tom
you can buy Clevites locally. You use standard size bearings if nothing spun and no maching required. ARP rod bolts are a good investment... its the weakest link on the stock motor. They stretch from high rpm and hp abuse... causing you to spin a bearing OR worse throw a rod. The forged internals from factory are strong enough... its our fasteners that SUCK. The headstuds i could careless about until you remove the head for something. Its the rod bolts that need attention. Anyways... temporary solution until i do a full motor build.
-Tom
-Tom
can you put his name down! but i forgot his sn on evom :/ lol
