TEMEVO/SFL
Old Feb 19, 2004 | 11:18 AM
  #2701
PRVRT's Avatar
This is a question for everyone who's car has been grounded or can answer it: Where does it idle at???? Mine is Idling at 1500rpms is that normal or is there something wrong?
Old Feb 19, 2004 | 11:30 AM
  #2702
Scooter's Avatar
It took mine a few days to settle down. I know it's almost been a week but just give it til after Moroso. If not we can rip everything out...
Old Feb 19, 2004 | 11:32 AM
  #2703
PRVRT's Avatar
I think its itching for a high speed run!!!! It hasn't calmed down since the 110 run!!!!
Old Feb 19, 2004 | 11:36 AM
  #2704
Dr Evo's Avatar
Mine idles just below 1000 rpm when it gets warmed up. When the motor is cold it jumps to 1500 rpm and then eventually it goes down to 1K in about 5 minutes.
Old Feb 19, 2004 | 11:39 AM
  #2705
PRVRT's Avatar
See I understand cold But after I run it it still does it and gradually comes down but then goes back up after I start moving again! I don't know!
Old Feb 19, 2004 | 11:56 AM
  #2706
stevEVO8's Avatar
Mine idles just under a 1000 896 or so once it is warmed up.
Old Feb 19, 2004 | 01:17 PM
  #2707
Jonasan50's Avatar
It should be around 850... That's the norm for almost every car... You're tellin me that it idles at 1500 and stays there all day long?? Something's wierd...
Old Feb 19, 2004 | 02:24 PM
  #2708
fastmarsh's Avatar
Hey GSG,
If your in Clewiston, then come to the autocross. We're about 1 hour from there. JK. Clewiston is a nice town. I have been looking out there for some property on the water. Kind of a family get away thing. I've also been looking at Sebring.
Everyone have fun this weekend and stay out of trouble.
Scooter, I got your phone number programmed in my phone, so I'll call if anything exciting happens.
Later all.
Old Feb 19, 2004 | 02:25 PM
  #2709
stevEVO8's Avatar
Has that happened since you got the car?
or has it been since you did the grounding kit?
I dont know that anything with the grounding kit would have done anything unless your causing a short somewhere in the engine compartment.
Have you mess with the BIS screw which adjust the idle?
on the dsms it was called a bis anyway.
Old Feb 19, 2004 | 02:33 PM
  #2710
EVO_ATE_U's Avatar
well i would think that if i had my car worked on by " hileah secients" then is understandable for the idle to do some weird things.......lol
Old Feb 19, 2004 | 05:54 PM
  #2711
stevEVO8's Avatar
BISS
The is one of the VFAQs for the dsm's but it should be the same....
Anyway I would first take the car to the dealer to fnid out why it is idling high. If not then I would get your manual out and try adjusting this screw.
Dont move it too much in either direction since this is for fine tuning your idle.
Old Feb 19, 2004 | 06:06 PM
  #2712
ElementalEvo's Avatar
Hey now...the term "Hialeah Scientist" is not meant to be in any way derogatory...please refrain from using it as such....lol....
By the way my car acted kind of stupid after we changed the ground wire...but i'm almost certain it was the MAS getting used to my giant intake after we reset the ECU...i've heard that this might happen...after ten to 15 minutes it quit acting like a little ***** and now it's fine....see you guy sunday...later
Old Feb 19, 2004 | 06:58 PM
  #2713
Scooter's Avatar
PRVRT
Let it be til Sunday and We'll ALL take a look at it. With our combined intelligence we're sure to screw it up for good.
Old Feb 20, 2004 | 04:10 AM
  #2714
EVO_ATE_U's Avatar
Talking
Hey now.......lol as we all know it was just a joke.
any way good moring to you all ...its 6.45 am i am sitting in my office trying to get evolved.
about the idle....dbl check all the connections before you do any adjusting...a bad ground or faulty wire will cause idle to do that.
well hope you all have a good day!
chris and mike .....good luck in ft myers(nationals)
well talk to you all later
gordon
Old Feb 20, 2004 | 04:53 AM
  #2715
Jonasan50's Avatar
My package is evolved.. But we are all used to the morning Evolving!!! Hahahahah
