TEMEVO/SFL
Old Sep 25, 2007 | 12:42 PM
  #38476
Profoxcg's Avatar
gauges.
what do you guys think of Omori gauges? I am lookin for the most stock looking gauges to place them on the center dash.
I read some post about them being nice and accurate then I read another post where the guy was says it was garbage...
I dont like the Defi's bc they are too big and i need the dumb module... even if I just wanted ONE Defi boost gauge
Old Sep 25, 2007 | 01:16 PM
  #38477
Evoryder's Avatar
Omori are nice gauges.
Old Sep 25, 2007 | 01:42 PM
  #38478
Profoxcg's Avatar
42 draft Designs make a nice 3 gauge din pod for 52mm gauges.
Im going to order that one and they also carry VDO gauges.
VDO gauges are very cheap.. I am assuming this is because they are mechanical and not accurated and just not good quality?
Old Sep 25, 2007 | 02:03 PM
  #38479
06MRV8Killer's Avatar
First off whats up everyone.
Second Omori are nice for what you are looking for, they are accurate from my experience....
Defi are sweet but your right about havin to buy the whole set up
Old Sep 25, 2007 | 02:08 PM
  #38480
Sig was way wrong....
New to this pretty obvious huh...
Seen alot of Evos in the area how many located in or close to Boca?
Old Sep 25, 2007 | 05:21 PM
  #38481
Evo Girlie's Avatar
nice but u can only boost up to 25 pounds, so if u are staying 25 and under u are fine
Old Sep 25, 2007 | 05:51 PM
  #38482
Profoxcg's Avatar
well what do most people boost when they are moded??
(Do VDO's suck)
Old Sep 25, 2007 | 06:11 PM
  #38483
Evoryder's Avatar
Most don't exceed 25psi...if you're using the Stock Metal BOV you're fine...however I would personally get something that reads -30-30psi
(Do VDO's suck)
I had a VDO on my 1.8T worked fine.
I boost 28psi now...
Most boost only 22/23psi with standard bolt ons
Old Sep 25, 2007 | 06:29 PM
  #38484
Profoxcg's Avatar
well from the 21.5 - 22 or 23 is there is noticeable difference in performance?
what gauge do you know of that looks nice (not flashy) that goes [-30 +30]
Old Sep 25, 2007 | 06:43 PM
  #38485
Evoryder's Avatar
Why not the defi gauge manual? I've been hearing good reviews on prosport gauges
http://www.prosportgauges.com/
21-23psi there is a difference if you modify your tune to reflect the new boost. (noticeable difference)
Old Sep 25, 2007 | 07:37 PM
  #38486
Everythings been solid since May no problems (Not going over 25 maybe spiked once or twice over) with Scott's tune some say its too aggressive other say its not i think is just right
Old Sep 26, 2007 | 04:55 AM
  #38487
Evo Girlie's Avatar
(Do VDO's suck)
people that run meth usually boost over 25 pounds as well if u put race gas and up the boost
I think u took my quote when it was meant to answer a question on gauges but damn you are boosting 25 pounds with those mods yikes, good stuff but I wouldn't boost more than 22-23lbs ::makes not to self for when Scott tunes mine::
GM Temevo, another rainy fawking day
Old Sep 26, 2007 | 06:13 AM
  #38488
Slick-IX's Avatar
welcome, i work in deerfield... i see a couple of evos now and then...
we having a meet this saturday at Towers, you might want to check it out
tell me about it, aint got hsit to do, but ***** away on the forums...
Old Sep 26, 2007 | 06:21 AM
  #38489
subaruwrx420's Avatar
You can also look at Stewart Warner gauges. I have a mechanical one that reads to 40psi.
http://store.summitracing.com/partde...5&autoview=sku
Also, I haven´t yet finished the tune on my car but I was spiking to 27psi on pump with a moderate increase in timing from stock. I only see 1-2 knock counts here and there, usually when spooling, but I understand it is somewhat common in the Evo world. I really need to take the time and finish the tune because I hate not being able to floor the car if I desire...I only give it 85-90% throttle.
My mods: Walbro, GM solenoid, Buschur catless TBE w/Magnaflow.
  #38490
Evo Girlie's Avatar
u are at work or home?
