TEMEVO/SFL
Old Jun 11, 2008 | 10:47 AM
  #42226
Evoryder's Avatar
Originally Posted by Slick-IX
are you ok?...no seriously, are_you_ok?... important? LOL.
-you said i was the slowest here, so i said you should try me now, with the mods i have... and you got all defensive bringing old stories and everything LAWL. you couldve just said that you gots teh Meht
yea i read all of that last night, jackoftrades metions it on one of his posts... hopefully i have the terminals i need here at work , you installed your meth kit yourself right? was it complicated? from teh looks of it the most complicated thing is tapping to teh ECU (and that doesnt seem hard lol)
Meth install typically doesn't require touching the ecu.
Pretty straight forward really.
1. Relay(ground, 12v direct to battery, trigger from boost switch, output trigger to meth pump to spray)
2. Boost switch for on/off applications.(tapped into pressure source for set point of boost to send voltage to trigger side on relay to have pump spray...most go for 15psi, good window so you're not spraying at part throttle)
3. Tap bung into one of intercooler pipes(preferably as close to the TB)
4. Mount pump
Thats a basic setup. Add Failsafe.
5. Another relay maybe(zeitronix does) Labonte, Aquamist use both flow sensors, anything below a certain threshold then voltage is sent to your ecu if you have a patch, mac valve to either switch maps or cut boost.
My setup cuts boost to 12psi wastegate pressure when my zeitronix settings are met. These are through a/f, boost..
Little more detail to installing the meth kit/failsafe...but it's pretty straight foward, unless you're getting the complete Aquamist kit w/ DDS3...that's a project.
You may need to take it easy on your soldering. Last time you tried to install one of the easiest things in the world resulted in a defective radio.
Originally Posted by Evo Girlie
old injury caught up with me, nothing now just healing time.
Slick: can't say if i didn't have it yet. As a matter of fact car is still w Tamer and I think today is when he is going to tune it for meth. Haven't been myself lately, maybe it's the drugs that took away mai sense of humor.
Wayne: i'll b in today after work
You should watch the HULK on friday, you wont feel like you got a split personality after that
Old Jun 11, 2008 | 10:57 AM
  #42227
Slick-IX's Avatar
4. Mount pump
lol i know, but for this i have plenty of room, and for the record teh innovate wb is a ***** to install, it comes with 2 different instruction you have to put together LOL, i dunno why they didnt just make 1 [period]
Old Jun 11, 2008 | 11:00 AM
  #42228
Slick-IX's Avatar
its ok, i had a feeling you were having a badday and you were taking it off on meh
x2 lol
Old Jun 11, 2008 | 11:45 AM
  #42229
krazirob's Avatar
i installed my HFS-5 kit from aquamist and it can be a bit complex....but once you get everything good to go you are golden.....
mine is set to 15psi boost cut but i can just turn it off and run normal boost (24psi) if i run out and cant fill up right away.....
the dds3 box is tricky but nothing you cant handle
Old Jun 11, 2008 | 12:05 PM
  #42230
TTP Engineering's Avatar
Where you at Robbie?
Old Jun 11, 2008 | 12:22 PM
  #42231
krazirob's Avatar
sh*t scott i totally forgot about sending you a pm.......its tomorrow now.......had to do some last minute stuff before i left........
I should be there around lunch time tomorrow, i promise or i will send you a paypal goodie.....LOL
Old Jun 11, 2008 | 12:39 PM
  #42232
Evo Girlie's Avatar
mai day was good, u made it irritated lol.
Jeff: . . .
edit: avoiding drama
Old Jun 11, 2008 | 01:33 PM
  #42233
Busy day tomorrow, have 4 Evo's we're working on. We should still be able to get you in on the dyno, np.
Keep in touch.
Old Jun 11, 2008 | 01:34 PM
  #42234
krazirob's Avatar
just my luck.......and today you are guys are slow huh........thats murphy for ya
Old Jun 11, 2008 | 01:43 PM
  #42235
Evoryder's Avatar
Jeff: . . .
what did she write b4 the edit
Old Jun 11, 2008 | 02:51 PM
  #42236
Slick-IX's Avatar
Keep in touch.
dude the shop is looking pretty nice
Old Jun 11, 2008 | 02:52 PM
  #42237
Slick-IX's Avatar
pwnt lol
Old Jun 11, 2008 | 03:37 PM
  #42238
Not exactly... Mostwanted is here installing the Tilton Twin carbon and we are about to put it on the dyno.
Old Jun 11, 2008 | 04:20 PM
  #42239
Evo Girlie's Avatar
hehe u will never know
Old Jun 11, 2008 | 05:17 PM
  #42240
Slick-IX's Avatar
did you see this yet?
https://www.evolutionm.net/forums/sh...d.php?t=334574
so tempting
