TEMEVO/SFL
Old Jul 22, 2008 | 06:25 AM
  #42451
Slick-IX's Avatar
Originally Posted by A so me go
I know that failsafe works because it went to wastegate psi when there was a tuning problem.
yeah you probably have the macvalve
Old Jul 22, 2008 | 09:16 AM
  #42452
diiirk@AwdMotorsports's Avatar
anyone have a stock ix shifter laying around? i need one.
Old Jul 22, 2008 | 09:35 AM
  #42453
Evoryder's Avatar
Originally Posted by Slick-IX
i am still a lil confused about jamie's harness and the macvalve tho... if the failsafe is activated: macvalve will bypass mbc and allow you only to boost wastgate psi, but what would you need the harness for then? to change maps? but it would change to the same exact map just with different boost
NVM it would also change the meth tune...
Yes. It would change the map. I am going to have a stock map which is rich as hell + the 14psi wastegate pressure...that way you help supress the knock and egt temps with the added fuel from the injectors where the meth was removing to make power.
So what brand is it ? So we do know a macvalve or valve of some sort is in the system.
Old Jul 22, 2008 | 11:53 AM
  #42454
Slick-IX's Avatar
I was reading that you can control boost ~14psi with teh Macvalve, just like with a GM selenoid... if i figure how to do this, it would also be a nice setup, and i wouldnt need the MBC no more...
Old Jul 22, 2008 | 01:11 PM
  #42455
Evoryder's Avatar
I didn't know you could do it with the macvalve
Old Jul 22, 2008 | 06:14 PM
  #42456
A so me go's Avatar
Labonte.Yes.
Old Jul 23, 2008 | 06:10 AM
  #42457
Slick-IX's Avatar
lol i had to ask ALOT to make sure, but theres ppl saying that the macvalve is even better then teh GM3port cause it lasts longer, and it would do the same exact thing...
Tunning it ofcourse would be different then tunning for a MBC... i might get into this aswell (<might need your help). you should look into this... specially since you plan on getting teh DDS, you would be able to switch to a safe map with still a high (but safe) boost ~22psi... and you wont need the laptop to switch maps, with teh DDS, it automatically does it for you when you turn it ON(meth map) or OFF(safe map)
Old Jul 23, 2008 | 06:39 AM
  #42458
Evoryder's Avatar
I don't see how a macvalve could do it seeing that it is either on or off. There are no degrees to it like a mbc and adjusting
Old Jul 23, 2008 | 07:20 AM
  #42459
Slick-IX's Avatar
it would work exactly the same way as a GM3port... heres a thread Evo_Kid made on how to control it... you would basically do the exact same thing...
the GM3port = Macvalve, which is also a 3port... dudical is running it like this, and also mentions it on his "howto"
Old Jul 23, 2008 | 03:58 PM
  #42460
98autogstspyder's Avatar
Anyone know of a apex silver ix jdm rear for sale in south fla? I will be coming down soon.
Is kami speed in Orlando the closest shop that sells them?
Old Jul 24, 2008 | 10:35 PM
  #42461
Bizo2's Avatar
off topic here guys
im looking to buy rims for the evo, but i need rims that can take our s. fla pot holes and i can take the track as well, any suggestions
thanks
Old Jul 25, 2008 | 04:15 AM
  #42462
Evoryder's Avatar
That i know of. You may get a better deal ordering online. What price do they offer?
Originally Posted by Bizo2
off topic here guys
thanks
This isn't new york...we have potholes, but not that bad. I've only heard of 1 person ever cracking their rim in SFL and that was a summabytch of a hole + good speed.
Old Jul 25, 2008 | 07:27 AM
  #42463
Evo Girlie's Avatar
off topic here guys
thanks
get wider+taller tires. What size are currently running and wha r u dropped on?
Old Jul 25, 2008 | 10:59 AM
  #42464
Bizo2's Avatar
17x8 oem, with a 1.4 front and .8 rear
Old Jul 25, 2008 | 11:01 AM
  #42465
Bizo2's Avatar
debating between advan,work, or volk
im on swift springs
