TEMEVO/SFL
Old Jan 2, 2009 | 06:19 AM
  #43351
Evo Girlie's Avatar
Originally Posted by purevibez
if you think about it, for the price of 1 of your volks, you could be a E85 stock turbo monster
"The Lightning Yellow Bolt" of FT.Lauderdale
sounds good but for now I will have to pass.
Old Jan 2, 2009 | 06:25 AM
  #43352
Slick-IX's Avatar
Originally Posted by Evo Girlie
am I the only one at work today.... FTMFL
i wish they wouldve gave me today off, but they didnt... either way theres nobody here to bother me and i can finish up some projects, listening to some music and surfing lol
Old Jan 2, 2009 | 06:27 AM
  #43353
Evo Girlie's Avatar
well worse for me is that I could have taken it off but because i'm still in my 3 months I don't get paid. I have nothing to do but i'll be fixing up old files and whoring it online all day.
Old Jan 2, 2009 | 06:38 AM
  #43354
Slick-IX's Avatar
yeah same here
Old Jan 2, 2009 | 06:46 AM
  #43355
purevibez's Avatar
ok Yadi. but remember, when your ready to come to the darkside ill be right here to walk you into it .LOL!!!
Old Jan 2, 2009 | 07:30 AM
  #43356
Evo Girlie's Avatar
we could always swap cars for a day lol. You know when u want to go slow and I want to go fast lol.
omg i'm getting nothing done here
Old Jan 2, 2009 | 07:36 AM
  #43357
purevibez's Avatar
lol dont want you to get me hooked on drugs. you meth addicts scare me.lol
Old Jan 2, 2009 | 07:38 AM
  #43358
pomod333's Avatar
lol. whats so bad bout meth?? or am i in the wrong mind set X_X
Old Jan 2, 2009 | 07:43 AM
  #43359
purevibez's Avatar
the taper after, the withdrawl on empty, the track marks. all the normal draw backs of an addiction. lol
i choose to get high on life and make the earth greener (on E85 of course)
Old Jan 2, 2009 | 07:46 AM
  #43360
diiirk@AwdMotorsports's Avatar
wise choice my friend.
Old Jan 2, 2009 | 07:47 AM
  #43361
Evo Girlie's Avatar
that's what i'm saying lol
Meth on the Car that is
I recycle so therefore i'm helping the planet
Old Jan 2, 2009 | 07:52 AM
  #43362
pomod333's Avatar
how does meth work??? im a noob at this stuff
Old Jan 2, 2009 | 08:06 AM
  #43363
Evo Girlie's Avatar
I would look into e85 before meth (alcohol injection) specially if u don't have meth already. Overall meth will be pricier and many times faulty(good kit will run u 500+, meth tank 5 gal 35+). Meth is basically a alcohol injection that u spray into ur inake track, soaks up heat and keeps engine cooler, gives u more power and allows u to run more timing. You are prone to have more problems with the meth then e85. However if u don't want to go e85 but do want extra power Meth is where it's at. Get a good kit with a good failsafe and don't go bunkers with the boost right off because i've seen people go from 24lbs to 34lbs with meth and being noobs they blow up.
Look into the thread made here for aquamist that has a crap load of info.
Old Jan 2, 2009 | 09:03 AM
  #43364
TTP Engineering's Avatar
There are a number of different kits in the market depending on your budget. For the best kit and safeguards available, it can run into $2500 range for Aquamist HFS-5 with install and zeitronix active wideband monitoring system there to cut boost.
The Aquamist HFS Kit alone retails for $949 and most shops charge around $800-900 to install it.
Our install pricing is much less, however it is about a days work and spider web of wiring throughout the car.
Meth injection turns on at either a predetermined boost level, a predermined airflow signal level, a combination of both, or by injector duty cycle.
The injection of methanol and its detonation suppression and intake air temp reduction will bump the effective octane rating to 105-115 depending on the % of methanol used in the injection tank and the number of nozzles and jet sizes used.
The benefit is the ability to tune and run the car as if it is on racefuel with more boost, advanced ignition timing, hence making more power.
Old Jan 2, 2009 | 09:12 AM
  #43365
purevibez's Avatar
thanks scott. that explains it pretty well
both simple and semi technical explanations in one post for you there pomod333
