Fynetune's 610awhp Evolution VIII
Old May 10, 2006 | 08:19 PM
fynetune's Avatar
STAGE 1 KIT FOR FYNETUNE IS ALMOST COMPLETE AND WANTED TO SHARE THE TEST RESULTS.
THIS IS A GT40 TURBO RUNNING C16 ON STOCK BOTTOM END AND HEAD WITH HKS 280 CAMS AND HKS CAM GEARS @ 33psi. WE ARE IN FINAL DEVELOPMENT WITH THIS KIT AND WILL CONTINUE TO SHARE NUMBERS WITH YOU GUY'S.
ENJOY THE RESULTS FOR NOW....
Old May 10, 2006 | 08:21 PM
expl0d's Avatar
jesus... stock bottem end? sick
Old May 10, 2006 | 08:33 PM
Kings Fan's Avatar
Good mother of the lord.... what happens after 6700 rpm?
Old May 10, 2006 | 08:37 PM
inco9nito99's Avatar
Wow thats ungodly...how are you able to run 280's on stock valvetrain? Or is this just to prove dyno numbers and not streetability/reliability. Those stock springs wouldn't be able to withstand the cam grinds on the 280's for too long IMHO.
Old May 10, 2006 | 08:52 PM
fynetune's Avatar
Before we where using 272's and notice that the cams where worn a lot but when we checked the spring tension they seemed to be fine. We have quit a few cars running on the stock springs remember the only difference between the cams is the duration, the lift is pretty close to the 272's and 264's. Drivability is more than fine even with these cams; I have not really noticed any difference in drivability from the 272's. However we are looking to go to ferrera valve springs sometime soon.
Old May 10, 2006 | 09:02 PM
04 evo's Avatar
Cool, OK, How much???????
Old May 10, 2006 | 09:07 PM
fynetune's Avatar
Well have numbers soon. I will post when kit is fully ready and available. We are trying our best to make this kit very close to the cost of a GT35R kit...
Old May 10, 2006 | 09:11 PM
04 evo's Avatar
What's the time frame?????
Old May 10, 2006 | 09:12 PM
fynetune's Avatar
another 2 - 3 weeks granted there are no fabrication issue's that need to be addressed..
Old May 10, 2006 | 09:21 PM
slowevo4me's Avatar
well, one thing is for sure, you know how to make decent top end power, especially on a stock block, but something has got to be done about the bottom end power. Just as an example, on less boost, I make about 70hp more @ 6500, and over 300hp and 300ft/lbs more at 5000rpm with my 35r. all this on 29lbs of boost.
Old May 10, 2006 | 09:25 PM
fynetune's Avatar
reason for that is stock compression is stock 9-1 ours has been lowered quit a bit with the 1.5mm toda head gasket we put on. We are still tuning and will share as we progress... Your forgetting as well from what I see your motor is a 2.4 vers a 2.0
Old May 14, 2006 | 07:40 PM
Boost Freak's Avatar
I am confused, Cause stock compression is 8.8:1.
Old May 15, 2006 | 07:19 AM
EVOMIZ's Avatar
so what will a 1.2mm headgasket do for compression?
Old May 15, 2006 | 07:23 AM
TURBevO8's Avatar
A freind of mine runs 280s on stock turbo and Meth. It surpised the hell out of me that it idled so smoothly after his tune. Then Friday I met some kid with a 2nd gen DSM with 264/272 and it idled like a cammed Chevy big block. Crazy.
Old May 15, 2006 | 02:34 PM
2003evo8's Avatar
those numbers will be good for 10's
