Fayetteville/Ft Bragg/Pope AFB -- TAKE TWO!!!
Old Dec 11, 2006 | 09:36 PM
  #421
ries's Avatar
*repost*
Old Dec 12, 2006 | 05:46 AM
  #422
theEVOdream's Avatar
I have a bung on my testpipe...cant I just use that as my source for the wideband instead of rewelding a new bung on the dp?
Old Dec 12, 2006 | 05:54 AM
  #423
bigric09's Avatar
yeah... if you have one in the test pipe already that you bought then you shouldnt really need another one, but most people put the bung for their wideband 02 in the DP right where it meets the cat delete... mainly because when it comes time for inspection, they can swap it out.... eric, what did you do with the 02 bung in your catback ? did you plug it ? what you can do is move your 02 sensor that is in your cat to the catback, i am pretty sure it has enough wire to reach and we can just plug the one in your cat delete until later.
i also vote for 3... not saying that it would, but should anything happen, you can always get your money back and it gives things time to play out and still mod
chris, brian got his DP coated by jethot... they are pretty cool, they have several coatings and will send you a catalog and vhs tape <-- pointless, with all of their products... go to their website. I got a quote to have my UICP coated and it was 65 i think. If you have the time, the coating is well worth it, Brians downpipe was almost touchable by hand after running the car for awhile. I'm not sure what the ams coating is, probably a brushed aluminum look... check with jet hot, they have chrome, black, aluminum, colors, whatever you want. Also, i still have that buschur upper pipe i need to give to you... i think you should have it coated as well... take out some of the scratches and coating the guy before me put on it in order to seal the "pin holes" he had on it
Old Dec 12, 2006 | 06:56 AM
  #424
Cirrusly Evolvd's Avatar
The AMS manifold was coated by Classic Coatings. It's their Cerma-Chrome or some other crap like that. It was very shiny when I first got it but not its more of a glossy grey. I recommend getting the Jet-Hot 2000 coating on all your parts as their chrome finish is only good for non-turbo applications. They have black, grey and blue as color options in the 2000.
My old AMS dp was coated in the grey and now my current parts are coated black. The stuff is awesome and like Ric said you can pretty much grab the dp bare-handed after running the engine.
Old Dec 12, 2006 | 07:33 AM
  #425
bigric09's Avatar
one thing though, im not sure if i would get headers coated in that grey you had... the finish was a bit rough for something that is so visible. if it is under a heat shield then yeah that would be great, or the DP, hotside, compressor housing 02, definitely... but for headers... whatever ams used looks great, but i bet jet hot has something a bit smoother as well.
Old Dec 12, 2006 | 08:41 AM
  #426
They have a white coating as well but dunno what the temp range is. Don't coat headers with their Chrome. It's only rated to 1300 degrees F and the header gets way hotter than that.
Old Dec 12, 2006 | 10:48 AM
  #427
R2RS's Avatar
the o2 bung that was in the catback, i plugged with a transmission drain plug when me and my friend put it on in charlotte, got it at the lexus dealership that he works at. i am probably going to go with #3. jason she's the girl you seen me with when you got out of the movies. did you see that big turd cutter she has? i used to date her like seven years ago and now that i'm back in nc we basically started where we left of. she likes the car and she doesnt mind rolling down the windows with the crank so thats a big plus!
Old Dec 12, 2006 | 11:25 AM
  #428
ries's Avatar
bwahahaha +1 guzillion for the rolling down of windows w/ a crank RS FTW
Old Dec 12, 2006 | 12:41 PM
  #429
A/c...ftw!
Old Dec 12, 2006 | 12:59 PM
  #430
ries's Avatar
Originally Posted by Cirrusly Evolvd
A/c...ftw!
a/c is a crutch....lol
Old Dec 12, 2006 | 03:59 PM
  #431
bigric09's Avatar
a crutch im happy to lean on every chance i get.... better hope you dont put on any weight, you sweat more when your a chunky butt.... i definitely need the a/c ...windows that roll down, the sunroof so what hair i do have can blow in the wind, oh and a radio .... SSL ftw !!! If i can run 11 sec with a few bolt on's and still be cumfy, im doing quite well....
Old Dec 12, 2006 | 04:10 PM
  #432
bigric09's Avatar
i know its been awhile... but you guys wanna help with an O2 install ? lol.... i just ordered mine from buschur and the ported coated mani ... should be fun... i welcome any help, i may have a ported and coated hotside to play with as well, not sure, there site is unclear, cant tell if there is a ported coated starting with a 10.5, or if they are just modding to a 10.5 and coating it.... will find out tomorrow, they didnt answer the phone
Old Dec 12, 2006 | 05:04 PM
  #433
ries's Avatar
ahhhhhhhhhhhhhhhhhhhhhhhh.....sure
are you going to get the O2 housing ported?
any new info on that toys for tots jump or is it too late to get onto the manifest???
oh, and my new car will be here within the next 7-10 days....supposedly
Old Dec 12, 2006 | 05:09 PM
  #434
bigric09's Avatar
outstanding, cant wait to see it, i wonder if it will be quicker then yours now with only a few mods added to it... just break her in right. the 02 comes ported and coated same as the mani... should be easy, and its amazing how easy the bolts came out of brians old mani and 02/hotside and heatshield with a little PB blaster.... sure wish we would of had some when trying to work on someone elses stubborn a$$ car
Old Dec 12, 2006 | 05:27 PM
  #435
ries's Avatar
I think w/ everything taken off the VIII and put on the IX (minus the cams) I can run a 12.5 or better w/ a good tune. But like you said I gotta break her in good first....
So you ended up going w/ the stock ported and coated O2 housing instead of a ss one....Im interested to see the gains you see....I bet itll pull hard as hell up top. When are you supposed to get the parts in? Ill be here during all of x-mas exodus, I figure I can visit home during my PCS to Lewis. + I wanna swap all the parts over to the IX
