Camp Lejeune/Jacksonville Evos
From: Tallahassee, but currently reside @ Camp LeJeune
yeah i got all day off, just got my appointment till about 1000, pat i need your # i got a new phone and lost all my #'s from before, bob do you work tomorrow
i was driving to my appointment this morning, and building speed when it sounded like something blew off, my asc turned itself off and wouldnt come back on, then iw wouldnt build boost at all but after i sat at my appointment for half the day, every thing was fine except the boost, this thing is starting to **** me off
Did you check to see if you're grounding out somewhere? If you know what you're doing with a multi-meter you might be able to narrow down the problem.
Isn't the ASC completely electrical? If so, I'm not too sure something "blowing off" would disrupt that. If there are mechanical components to the ASC then I would try running down that path to see the potential problem (checking the vac lines as others have stated).
If you need help tracking down potential electrical issues shoot me a PM. My brother does all the electrical work with cars. If it's something electric, he can narrow it down or fix the problem for you. Hope that helps man!!
thats what i thought about the hose, but i couldnt find anything not connected, and after the car sat and cooled off for a few hours, check engine light went off, and asc turned back on, so im kinda lost here
The car may have seen a condition it didnt like, went to limp mode. Then reset itself afterwards. As long as she is good now.
Bob... can you give me a call tomorrow sometime during the day ?
Guys stay tunned Wynn's / Jestr tunning at the drag strip in Valdosta G.A. we expect you guys to come by and hang out and get you top end internals cleanned up with Wynn's fuel system cleaners and also get tunned or re-tunned by Jestr ,,,, stay tunned @ https://www.evolutionm.net/forums/sh...ighlight=wynns
Not a prob. I haven't checked the forums in a bit... I'll txt you now, and def. call you tomorrow!
it cant hurt, but not sure if it will help any honestly. It doesnt sound like your problem is the wastegate. You should leak test the car. If you were closer i'd help you out. Ill look at her monday while im there if you want.
