Need help from Atlanta Evos
Old Sep 15, 2003 | 08:02 PM
Racer RS X's Avatar
Ok guys, after meeting Saturday I installed the Boost Gauge and I got it right.
Now the problem. I can not figure out the manual boost controller. I see the place to install the t-connector between the BOV and engine, but I cannot see the place to connect to the waste gate actuator. If some one could help me out that would be great. I have read the Brusher instructions (they suck), and read the installation guide on this page and another, but the pictures are not clear.
Any help is appreciated.
Thanks
Old Sep 16, 2003 | 07:34 AM
snapb1's Avatar
Have you looked at these install instructions yet: http://www.jonesland.com/evo/MBC_Install.htm
From the looks of it, the wastegate actuator has to nipples. One goes to the FBC and the other is the one you run your hose to.
I don't know if this helped you at all, but if you have alread disconnected your hoses, then you should have disconnected one of the lines from the wastegate. I will be going through this in a few days, so let me know how it turns out.
Old Sep 16, 2003 | 12:01 PM
Rally Red's Avatar
Those are the instructions i used for the install. The second picture is where you install the hose. You take of both hoses from the wastegate (gold) and the turbo outlet (silver). Then you cap the turbo outlet, silver piece closer to back of car, and you put the new vaccume house on the waste gate, gold piece closer to front of car. I hope this helps you out, let me know if you have anymore questions.
snapb1-if you need any help with yours just let me know and i'll meet up with you some where.
808boost
May 6, 2009 08:14 AM
sharkm87
Nov 20, 2008 09:37 AM
joon82
Feb 7, 2007 01:47 AM
Z_Lancer_Man
May 2, 2006 08:40 AM
evoracer32
Feb 24, 2006 09:13 AM
