Camp Lejeune/Jacksonville Evos (NEW)
Old Mar 30, 2010 | 07:57 AM
  #151
alicea8541's Avatar
By the way, loving my stay at Fort Pickett.
Old Mar 30, 2010 | 07:59 AM
  #152
bigric09's Avatar
Not at 22 psi.... the time and trap are possible for sure, but not at 22 psi, and i'd find it harder to believe on a 9.8 hotside.
Old Mar 30, 2010 | 10:45 AM
  #153
SRTRaceR04's Avatar
That's what I was saying to him. I was kind of on the spot when I met him and he's telling me these things. I didn't want to immediately go into "you're sooooo full of ****" with my responses so I tried to keep it polite. By no means did I agree with him though. I used the phrase "that doesn't make sense" several times in our discussion. He kept insisting that the turbo was ported, but I relayed to him that it still wouldn't make THAT much of a difference.....especially at 22psi. If he had like a 75shot of nitrous somewhere in his mod list that he wasn't informing me about then ok I can see that.
And yeah 11.3 at 129 is possible, but given the other information I found that one hard to believe too. With his power level (if he's even making that power) I'm more able to somewhat believe the et than the trap speed though. Although not with a 1.8 60ft.
Old Mar 30, 2010 | 10:57 AM
  #154
bigric09's Avatar
its almost like he left out the fact that is stock turbo is a sequential setup and it is pushing a 35R
Old Mar 30, 2010 | 01:35 PM
  #155
stock_evoIX's Avatar
I was wondering where you were hiding.
Dont worry we have a 3 week field op in ft bragg next week
Old Mar 30, 2010 | 04:19 PM
  #156
evozmarine's Avatar
anything going on this weekend?? oh and there's an auto-x at cherry point on sunday april 11th if anyone's interested. register at www.myautoevents.com
Old Mar 30, 2010 | 08:05 PM
  #157
sixers0307's Avatar
i know how u feel about that one buddy. i just got back today from bragg...sucked big time. 3 weeks felt like FOREVER!!! make sure if ur gonna leave ur car sitting while ur gone disconnect the battery. i forgot to do mine and needed a jump to get the car started lol
Old Mar 31, 2010 | 08:47 AM
  #158
Paintballer81's Avatar
i plan on it!! if i can even get this ***** to run perfect for more then a week.. went and got the headstuds installed only to find that the timing belt is lose and the cams had already skipped a tooth and are off timing. and when i say lose i mean and inch of play LOSE. like a french ***** lose. or your ex girlfriend lose.
luckily i have to go redo all of that to put in my new cams BUT it is just another thing that i have to work on..
Old Mar 31, 2010 | 09:45 AM
  #159
bigric09's Avatar
you shouldnt have had to do that with cams...
Old Mar 31, 2010 | 11:52 AM
  #160
evozmarine's Avatar
I have to fix some boost leaks myself, and i just ordered a ported BBK, driveshaft, ported intake/throttle body, exhaust mani, and billet motor mounts..if anything i at least hope to have the driveshaft and mounts installed by then.
Old Mar 31, 2010 | 11:55 AM
  #161
Force-Fed Performance's Avatar
you may want to do compression when u get those cams back in time bro. you can bend a valve VERY VERY easily if the timing is off. 4g63 is a interference motor
Old Mar 31, 2010 | 12:06 PM
  #162
06MREvo's Avatar
I don't know if anyone else has seen the yellow Evo rolling around here, but I finally got to talk to him. Here's what I gathered:
His car apparently makes 390whp with a stock 8 (9.8 hotside) ported turbo running at 22psi.
Apparently he has cams (sounded like 272's, he couldn't tell me what kind though) and nothing else and has revved it a couple times at the track to 8500rpm (he doesn't know if he has headstuds, but definitely does NOT have anything done to the head otherwise)
Apparently he ran a 11.3 at 129mph (with a 1.8 60ft) with said modifications and power level.
Planned to put a 4G67 block (I've heard of it, but don't know much about it) with an HKS turbo of some sort
Seemed like a nice enough guy, but the information shared with me seems a bit.....skewed. I know a bunch of people have seen him, but no one seemed to know him or have talked to him. Well....I have now.
And no he's not on the forums. This is apparently his first "tuner" car.
No fuc*king way...maybe a 12.3 @ 109...129mph???? Hahaha....
Old Mar 31, 2010 | 05:35 PM
  #163
Psquared's Avatar
Paintballer..how did your T belt come loose doing the headstuds?? Where did you take it? Do you know it's off a tooth? Is it running like poo? Hit me up if you need a hand doing the comp test. I just did one on my car. It's pretty cake, just need a decent rental tool from the parts store. (free)
Old Apr 1, 2010 | 02:26 AM
  #164
JReid's Avatar
are you with 2/9?
Old Apr 1, 2010 | 09:14 AM
  #165
Originally Posted by JReid
are you with 2/9?
I sure am
