My EVO is sick. Need help
Old Jun 19, 2004 | 10:34 PM
Lightsped's Avatar
Question My EVO is sick. Need help
So my car is 100% stock, and has 7100 miles on it. I don't race or anything like that. Occasionally I will run it up through the gears on a on-ramp, but that is about it, and that is not a everyday thing.
So tonight I was at highway speed, I drop down to 3rd, floor it, and as my car acclerates, it quickly runs out of steam at 6k rpms. It is like it ran out of breath. It was very noticeable.
Acclerating through 1st and 2nd is fine, it is just 3rd gear and higher that I loose alot of power at 6k rpms.
Any ideas? Thanks
Old Jun 20, 2004 | 04:33 AM
Jonasan50's Avatar
That's is normal for the pig-rich fuel mapping for the stock EVO... Buy a SAFC or get it reflashed, that will go away... Nothing is wrong with your wonderful ride...
Old Jun 20, 2004 | 04:39 AM
machron1's Avatar
If it is accompanied by a high-pitched wheezing sound, make sure both of the plastic fasteners are in your air scoop. Otherwise, it will cause a high enough vaccuum @ high rpm to suck onto the underside of the hood & cut off the airflow to the engine.
Old Jun 20, 2004 | 06:34 AM
bahamut's Avatar
indeed.
a failsafe point from mitsu.
Old Jun 20, 2004 | 06:59 AM
Lightsped's Avatar
Actually, I do only have one fastener on the intake. I'll locate another fastener for the intake and try it again.
I know it isn't normal because my car never ran out of breath like this before. I have had it a year so I would have noticed this by now.
Old Jun 20, 2004 | 07:03 AM
en1gma19's Avatar
^ I think someone else posted something about his 3rd gear running out of oomph at 5k about a week ago. See if you can find that thread, maybe there's some helpful info there.
Old Jun 20, 2004 | 07:05 AM
en1gma19's Avatar
I just found the thread for you. There's not too much helpful info in there though
I guess you could pm the guy that started it and see if he figured anything out.
https://www.evolutionm.net/forums/sh...light=3rd+gear
Old Jun 20, 2004 | 08:15 AM
EvoJimbo's Avatar
Y was my post deleted?
Old Jun 20, 2004 | 08:44 AM
Lightsped's Avatar
EVOJimbo, I didn't delete any posts in this thread. Now back on topic....
Ok, I checked under my hood today. Noticed that BOTH the snaps that secure the intake to the front frame of the car were gone! I located some new snaps and secured the intake. Wow, back to full power again! Feels great!
Thanks for the help!
Old Jun 20, 2004 | 09:31 AM
Kelmar's Avatar
Good to hear that it's back to normal!
Old Jun 20, 2004 | 10:49 AM
EvoJimbo's Avatar
My bad..there are two identical post in different sections.
Old Jun 20, 2004 | 11:18 AM
machron1's Avatar
Now the question is, where did they go? Check your air filter, as they are too large to bypass it normally. Mine ended up there. has a new part number for them w/ a cross-tip head (for removal of them, still push to insert). Glad your evo is back to normal again.
Pmay86
Lancer Troubleshooting
Aug 3, 2017 03:39 PM
Kilgore_evox
Jun 11, 2017 05:05 PM
youra6
Dec 21, 2016 12:54 PM
Peter Colindres
26
Mar 14, 2016 06:35 AM
MarkM
18
Jun 28, 2010 06:37 AM
