2008+ lancers/Ralliarts/EvoX problem starting?
Old Dec 12, 2011 | 08:09 AM
  #31
evo_soul's Avatar
Originally Posted by s84kam
i already know if this keeps happening, my starter is going to go... and thats more money that i dont have
s84kam, what fuel do you typically use on your car? which gas station?
Old Dec 12, 2011 | 08:45 AM
  #32
Slyy's Avatar
It's got nothing to do with the gas we use. I use shell's winter blend blah blah and it still happens.
Old Dec 12, 2011 | 08:55 AM
  #33
laksman91's Avatar
Thats what I used in my Ralliart.. connection?
Old Dec 13, 2011 | 04:12 AM
  #34
s84kam's Avatar
I use regular. And the gas stations are all random since I buy what ever is most convenient. Usually Esso and Mac's.
Old Dec 13, 2011 | 07:35 AM
  #35
evo_soul's Avatar
Well if it isnt linked to ethanol, than it is ignition related or something beyond the info I have from Japan.
Old Jan 6, 2012 | 12:53 AM
  #36
volksjager's Avatar
same issue...gonna go check my relays now...
Old Jan 7, 2012 | 06:47 AM
  #37
s84kam's Avatar
Maybe the new relays will work for you. They did not for me.
Old Jan 7, 2012 | 06:59 AM
  #38
Widoww's Avatar
Winter gas I wouldn't use really..if you guys aren't using 91 oct then you face problems lol
Another thing to check is timing chain seems alot of people have issues and this seems to be a huge cause of it. Someone even posted he drove home fine turned car off, started it the next day and that's when the chain messed up.
Check relays, and use good fuel not cheap *** watered down stuff.
Fully stock? Take to the dealer have them fix for you. If you got boltons then get a good tune up
Old Jan 9, 2012 | 04:13 PM
  #39
s84kam's Avatar
my lancer is stock and it happens not only in winter but all year round. And no octane has nothing to do with it.
Old Jan 10, 2012 | 11:21 AM
  #40
mikeszutu's Avatar
Registered User
I'm planning to take the car back in because it had a problem starting up today.
Old Jan 10, 2012 | 12:49 PM
  #41
TrailBrake's Avatar
I had occasional starting problems until I switched to an Optima Red Top 35 battery. I always use 94 octane, so the grade of gas isn't a factor and I frequent the same couple of stations exclusively.
Since I don't drive my car that often, I do a 2amp trickle every couple of weeks to keep it topped up. So far that has solved the issue for me.
Old Jan 12, 2012 | 05:01 AM
  #42
s84kam's Avatar
Originally Posted by TrailBrake
I had occasional starting problems until I switched to an Optima Red Top 35 battery. .
I might try this because I've been experimenting as well. I have read if you lay off the fog lights it usually does not happen. So I've stopped using my fog lights for an entire month and I haven't had this issue yet this is unfortunate because I love using my fog lights on my evo x.
Maybe it has to do with our battery output.
Old Jan 12, 2012 | 05:44 AM
  #43
TrailBrake's Avatar
You might be onto something with the fogs, as I have the JDP fog delete kit so no drain there.
Old Jan 12, 2012 | 07:18 AM
  #44
Widoww's Avatar
I turn off all ac controls, radio lights etc when i park and let idle. I'm back using the stock panasonic battery as my fp red destroyed the odyssey pc680 I had in it. Cranking amps with stock battery is 10x better. And I let it sit for a full year lol
Old Jan 13, 2012 | 05:01 AM
  #45
s84kam's Avatar
Guys who are having this issue, Dont use the fog lights. I'd like to know if this may work for others.
I turned on my fogs on my sport back and I got the no start the day after. My evo on the other hand is still going good for a month. I really hope it's the fog lights that is the issue.
Anyone without fog lights, are you guys having issues as well?
