New! BLOX Racing Front Engine Roll Stopper!!
My install SUCKED, I stripped my rear crossmember bolt because the engine/subframe was sagging a bit (05 w/ 50k miles on it) so the bolt holes were not lining up. To anyone else with this problem: bolt down the mount to the crossmember tight. Bolt it in loosely to the mounting position, then take a nice long phillips screwdriver and stick it into one of the front two bolt holes on the crossmember. Have a buddy push back HARD until the rear bolt hole lines up PERFECTLY. Thread this one in 90% of the way and then install the other bolts.
I wasted 2.5-3 hours driving around looking for a M12x1.25 tap (good luck finding one of those, very uncommon!) to re-thread the rear bolt-hole.
Initial review: AWESOME, car even sounds meaner! I'm going to drive it for a week, then post a full review.
I ordered mine on LAST Monday...the 21st....I dont even think its shipped yet, whats the deal?
My name is Hunter.
Fudge! And I purchased mine at full price ;-( came out to 107$...What was the special price
My name is Hunter.
Hey Hunter, sorry about that! we must have missed your online order when we were processing them daily. I just found your order and will get it processed right now. Also you have a pm
Because the mount/bushing is much stiffer than sotck, the vibrations are now be transfered to the chassis instead of vibrating on the engine and transmission. When all the moving parts are placed in an improved steady position, the engine noise will also be different.
