Spark Tech Ignitions INFO HOTLINE!
Heres my 4G64 chrome caps with the wrinkled black plate!! This is on my 2001 Galant with evo 8 head swap..Big thanks to Craig!Awesome product!
SparkTech
SparkTech
^ Thanks Craig I cant wait to see how this product works! It should be up and running in the next month or so. Im just getting the last couple of exterior parts and should be painted around the end of March aswell
Here at Spark Tech we have spent countless hours, improving and perfecting our systems. It is through all the Research and Testing that we proudly bring you this solution. Many are aware of an annoying part throttle miss/stumble associated with some of the other C.O.P systems on the market. This issue can sometimes be masked in tuning and is often attributed to large cams and heavily modified engines. This couldn't be further from the truth. I've even seen recommendations to increase the plug gaps. This will not rectify or get to the source of the problem. It's all in the wiring. We are proud to be able to say our systems are truly 100% compatible with the stock ecu and standalone ecu's... Not to mention, it looks great! You will be proud to show off your engine bay with this high quality and well engineered product.
If you are tired of excuses and are looking for better driveability, we have a guarantee for you: If this upgrade doesn't make a noticeable difference in the idle quality/driveability, simply return it for a FULL Refund.
These upgrades will work with any system on the market utilizing 300m coils and the M & W Pro-12 cdi (cdi NOT included).
These upgrades are 100% Plug and Play. They come with the billet aluminum plate that is featured in our PRO system, that starts off at $1196.17.
We think that your car is as unique as you are. And your ignition should be the same! This is why we offer many different options to suit your various needs. All Spark Tech Upgrades feature military spec wire & heat sleeving, stainless steel hardware and sealed marine grade fuse holders. Our wiring harnesses and workmanship are warrantied for lifetime (to original purchaser).
1. Spark Tech Complete Upgrade -
This upgrade features 4 brand new coils with 1year warranty. This upgrade retails for $637.00. With this upgrade all you need is the M&W Pro-12 CDI Unit. Here is a picture of the complete upgrade with the new coils.
2. Spark Tech Pro Upgrade Tune up Kit -
This system will require you to have the M&W Pro-12 CDI Unit along with (4) 300M coils. The upgrade comes with new boots and stainless steel mounting hardware for your existing coils. It is recommended to inspect your current coils for any damage.
This upgrade retails for $457.20.
Here's a picture of the Upgrade Tune up Kit
You also have 3 mounting plate finishing options :
* Powder coated wrinkle black (standard)
* Polished (+$26)
* Anodized purple (+$45)
POWDER COATED WRINKLE BLACK
POLISHED
PURPLE ANODIZED
Also available and only available through Spark Tech and our dealers is our Quick Disconnect Option
This option enables users to quickly separate the mounting plate and coils from the balance of the wiring system. This makes changing plugs & other routine maintenance easier as the entire system does not have to be removed or disconnected.
This is a high quality, sealed connector. Designed for high heat, industrial, automotive and marine use. It is specifically designed for power and signal connections. There is little to no signal or power loss.
*This option is +$65
* Polished (+$26)
POLISHED
PURPLE ANODIZED
These are pretty popular with guys with the other not so aesthetically appealing system. No part throttle surging either especially on stock ecu.
