Shearer Manifolds 02 Dump RELEASED!!!
Old Jul 19, 2009 | 02:44 PM
  #106
EVOIXreno's Avatar
Mike on the graph, were there any tuning changes or just put it on and dyno'd it?
Just asking to see if boost increased or AFR changed...you know the basics
Cory
Old Jul 19, 2009 | 03:22 PM
  #107
AWD Motorsports's Avatar
Cory
Id have to ask derek the tuner about boost to be sure.. I know the car was maxed out on the tune it had with the megan 02 housing.. We switched housings and then derek had to retune for a few pulls to get everything back in order.. The dump will lean the car no doubt..
Mike
Old Jul 19, 2009 | 04:02 PM
  #108
JDM_MR's Avatar
where is the graph located???
Old Jul 19, 2009 | 04:03 PM
  #109
EVOIXreno's Avatar
page 1
Old Jul 19, 2009 | 04:07 PM
  #110
s.e.a.n.'s Avatar
I'm sold, this will be my next mod for sure.
Great product, the price is steep but you gotta pay to play.
Old Jul 19, 2009 | 04:30 PM
  #111
MillDogg13's Avatar
Mike, I sent you a pm.
Old Jul 19, 2009 | 04:41 PM
  #112
diiirk@AwdMotorsports's Avatar
Cory
No significant changes to the tune after the install. The car actually leaned out a bit and made more than the 452/457 graph posted on the first couple of pulls, the only tuning i did was to get back to where it was before. same boost, same timing, just straightened out the AFR. Prior to the dump the car was basically stuck in the 420's, it would not respond to any changes, something was indeed holding it back. after the dump everything pretty much opened up and the car started making real power.
Old Jul 19, 2009 | 04:44 PM
  #113
EVOIXreno's Avatar
Originally Posted by diiirk
No significant changes to the tune after the install. The car actually leaned out a bit and made more power on the first couple of pulls, the only tuning i did was to get back to where it was before. same boost, same timing, just straightened out the AFR. Prior to the dump the car was basically stuck in the 420's, it would not respond to any changes, something was indeed holding it back. after the dump everything pretty much opened up and the car started making real power.
WOW... I have the MAP O2 dump/DP combo on the way... hopefully I will get similar gains
Old Jul 20, 2009 | 03:26 PM
  #114
casual's Avatar
someone has to have pics/vids by now...
Old Jul 20, 2009 | 03:42 PM
  #115
dmoevo's Avatar
i have these that i took with my phone...
Old Jul 20, 2009 | 03:45 PM
  #116
dmoevo's Avatar
it does not touch ANYTHING, licp a/c line..etc
Old Jul 20, 2009 | 05:37 PM
  #117
casual's Avatar
nice...wonder how it sounds, can we get some vids now?
Old Jul 20, 2009 | 05:40 PM
  #118
dmoevo's Avatar
ill see if i can get some vids tonite.
Old Jul 20, 2009 | 06:43 PM
  #119
casual's Avatar
great, did you get a CEL once this was installed?
Old Jul 20, 2009 | 06:47 PM
  #120
You will not get a CEL from the dump.. The 02 sensor goes right back in the housing like stock..
Mike
