Shearer Manifolds 02 Dump RELEASED!!!
mike
I installed tonight the car pulls harder on a roll in 1st when boost comes in its spinning the tyres easy but I will be removing tommorow and putting it up for sale locally. What I noticed is that on idle I am leaking through the dump not sure if it is suppose to be so or if my wg flapper is not sealing proper, its just too loud for me.
Sounds like you've reused the stock gasket between the turbo/O2 housing - which is the wrong thing to do. You need to install it with a divided gasket which should come with the O2 from new...
How can you ensure your turbo mating surface is exactly flat so there will be no leaking? Wouldn't it be easier to just include a gasket with the O2 especially for the price you're paying for it!! All the other O2s come with them...
Actually they all did not always come with gaskets. We installed probably 20 epm dumps and has better luck without the gasket. Never had a leak the the o2 side. It's cast and usually flat.
With that experience we opted to stay with no gasket on these. Dmoevo has no gasket and no leaks.
Mike
Mike
Mike,
I have maxed out the stock turbo on my setup! we did back to back runs at 30psi vs. 35psi and didn't even pick up 1hp. I have a 25psi wastegate and a ported megan O2 just to let you know. Since I have the 25psi wastegate; do you know if the wastegate is even open at redline? Trying to figure out if my wastegate will shut off after my spike! That would sound kind of funny with it open during 4-6k then closed from 6-8k. Thanks for your help!
Mike
Mike
MIke
Mike,
Mike
Mike
BUMP for question
Mike,
Mike
Mike
Mike
Mike
I have always used gaskets on my turbo piping on previous cars. Usually its just a real thin SS gasket, i wouldn't go without one. Things might lay flush at first without a gasket but after a while the high temp distorts the flanges slightly and usually leaks. Nothing major really, just some black soot around the mating surface. The O2 dump looks nice, although i like the recirc better, not a fan of blowing exhaust into my engine bay. If i did use it, i would hook it up to an external WG and ditch the crappy internal style. But thats just me :P
