Shearer Manifolds 02 Dump RELEASED!!!
Old Jul 23, 2009 | 10:05 PM
  #151
dipsetinallday's Avatar
Originally Posted by dmoevo
trust me it does not cause ANY creep whatsoever. that was one of the first things that we checked for and the guys at AWD would not sell the product or promote if it did not function properly.
remember diiirk also tuned it right after it was installed.
So if you do a pull on a cool night rolling in fourth gear and hold the throttle to redline you dont get any boost creep what so ever?
Old Jul 24, 2009 | 10:06 AM
  #152
diiirk@AwdMotorsports's Avatar
any car with a boost controller will boost more on a cold night, especially in 4th gear. but that is not boost creep. boost creep was in issue with certain dumps not having enough room inside for the wastegate flapper to fully open, with half open wastegate, boost rises after peak boost, rather than taper like it should. just one of the many things that were kept in mind when making this dump, setting the shearer apart from the rest.
Old Jul 24, 2009 | 01:27 PM
  #153
s.e.a.n.'s Avatar
Originally Posted by ssmdc5
this is why i cant figure out what i want. This is a fabulous piece!
But there im torn between the two opinions of 2 reputable shops.
Thats the thing about the forums.
One person says one thing and another person say something else.
The only way to really tell if it work is if you try it out.
Old Jul 24, 2009 | 01:39 PM
  #154
AWD Motorsports's Avatar
The difference is we have actually tested this exact piece.. While i have GREAT RESPECT for Dave you cant knock something til you try it and he knows that as well as anyone.. Once results start posting up i am sure you be able to make an easy decision..
Btw.. The EPM dumps did work also but they didnt fit as well.. There are Dozens of reviews on HP gains with it..
Old Jul 24, 2009 | 02:01 PM
  #155
Paintballguy's Avatar
just got mine today. hopefully i can get a chance to install it soon. great looking piece btw.
Old Jul 24, 2009 | 09:42 PM
  #156
casual's Avatar
^^ i expect pics and vids!
Old Jul 25, 2009 | 02:55 AM
  #157
Levar's Avatar
Veteran: Army
I'm pretty much sold on the Shearer O2 dump.
Old Jul 25, 2009 | 08:06 PM
  #158
W2J's Avatar
W2J
I installed tonight the car pulls harder on a roll in 1st when boost comes in its spinning the tyres easy but I will be removing tommorow and putting it up for sale locally. What I noticed is that on idle I am leaking through the dump not sure if it is suppose to be so or if my wg flapper is not sealing proper, its just too loud for me.
Old Jul 25, 2009 | 08:22 PM
  #159
Did you put the factory 02 gasket on with the dump?
Old Jul 25, 2009 | 08:25 PM
  #160
W2J's Avatar
W2J
yes sir I reused the gasket I had plus I applied red silicone to make sure everything was sealing correct.
Old Jul 25, 2009 | 08:31 PM
  #161
Honto's Avatar
It was leaking through the center of the stock gasket.
Old Jul 25, 2009 | 08:36 PM
  #162
W2J's Avatar
W2J
^ I think you making alot of sense re gasket leaking in the middle!!!!
Old Jul 25, 2009 | 08:52 PM
  #163
Honto's Avatar
You either can put JUST silicone all around the flange or get a "ebay" style gasket that keeps them separate.
Old Jul 25, 2009 | 09:12 PM
  #164
project_skyline's Avatar
It will leak with the stock gasket.... lol
Old Jul 25, 2009 | 09:17 PM
  #165
CO_VR4's Avatar
Just install it without any gasket or silicone crap at all. It's milled perfectly flat, and as long as your turbo mating surface is flat, you have no worries...
