ETS Evolution 8/9 Intercoolers (Track Proven)
Old Aug 27, 2010 | 01:44 PM
ETS Michael's Avatar
ETS Evolution 8/9 Intercoolers and Intercooler Kits (Track Proven)
The ETS Lancer EVO Intercooler is the best on the market, bar none. It features bolt on installation, eliminates the two up-pipes to the intercooler and fills the whole grill with core for a killer look and maximum efficiency. This unit also retains the factory crash bar and splash pans (3" and 3.5"). The kit includes the intercooler, mounting hardware, silicone couplers, and SS T-Bolt Clamps.
The ETS EVO Piping kit is designed to eliminate many of the unnecessary bends in the stock piping. Our piping starts off by immediately expanding into 2.5” diameter right off of the turbo elbow. This replaces the tiny 1 3/4” factory pipe and instantly frees up 15hp and greatly improves spool up. From here it follows the core support and wraps around to mate up to the intercooler. Once the air passes through the intercooler, the piping takes a short direct path around the core support, over the transmission and straight up to the throttle body. This unique routing is over two feet shorter than the stock routing which results in greatly improved spool up and transient response. With an 11% increase in cross sectional area, flow is increased as well.
Also available for those with a Front Power Brace from Cusco. We make a bolt on intercooler that fits within the brace.
Note: Does not fit stock airbox.
Don't be fooled by cheap imitations, this is the same intercooler we run on our 8-sec evolution 8.
Features:
  • Pressure Checked at 35psi
  • Bolt on design retains crash beam (3" and 3.5")
  • Fills entire grill with core
  • Eliminates excessive piping
  • Full Mandrel Bent 2.5" Piping
  • Stainless Steel T-Bolt Clamps
  • 3-Ply Reinforced Silicone Couplers
  • Short Route: Two feet shorter than stock
  • Lower piping flows over 20% more than stock
  • Upper Piping flows over 12% more than stock
  • 24x11.5x3.0" Bar & Plate Core, 1058cfm-700hp at 79% efficiency (Direct Replacement)
  • 24x11.5x3.5" Bar & Plate Core, 1127cfm-750hp at 80% efficiency (Direct Replacement)
  • 24x11.5x4.0" Bar & Plate Core, 1219cfm-820hp at 81% efficiency (Direct Replacement, - May require trimming of crash beam)
  • Recirculation kit is only needed for Mini Battery UICP (Stock battery UICP uses stock recirculation pipe)
  • Available in Silver, Black, Blue, Gold, and Red
* Wide Tank
* Standard Tank
* Piping Kit
* ETS Mitsubishi Evolution 8 Intercooler Standard Tank (24" Core, 33" Overall)
* ETS Mitsubishi Evolution 9 Intercooler Wide Tank (22" Wide Core, 33" Overall)
* ETS Mitsubishi Evolution 8/9 Intercooler For Cusco Powerbrace (20" Wide Core, 33" Overall)
* ETS Mitsubishi Evolution 8/9 Anodized Intercooler Option
If you have any questions or need a price quote / package deal, let me know!
We also offer the following parts for the Evolution 8/9.
ETS Evolution 8/9 Upper Pipe
http://www.extremeturbosystems.com/M...duct_info.html
ETS Evolution 8/9 LP2 Lower Pipe
ETS Complete Evolution 8/9 Piping Kit (Short Route or Stock Route)
http://www.extremeturbosystems.com/M...630/index.html
ETS Evolution 8/9 Turbo Kits
Standard Style: http://www.extremeturbosystems.com/M...duct_info.html
Front Facing: http://www.extremeturbosystems.com/M...duct_info.html
ETS Evolution 8/9 Exhaust Manifolds
T3: http://www.extremeturbosystems.com/M...duct_info.html
Stock Replacement: http://www.extremeturbosystems.com/M...duct_info.html
V-band: http://www.extremeturbosystems.com/M...duct_info.html
ETS Evolution 8/9 Exhaust System (JDM or USDM)
ETS Evolution 8/9 Intake Kit
ETS Evolution 8/9 Intercooler Only
ETS Evolution 8/9 Mini Battery Kit
http://www.extremeturbosystems.com/p...duct_info.html
Thanks,
Michael
Old Aug 29, 2010 | 02:28 PM
o-townFLA's Avatar
ETS TRACK PROVEN...!
3" left - 3.5" right
Old Aug 29, 2010 | 02:43 PM
goforwand's Avatar
Another ETS track car with 3" IC and complete piping! Great fit, easy install, and reliable under extreme conditions
Old Aug 29, 2010 | 03:58 PM
ssg_petty_210's Avatar
The best products hands down. I will be needing to upgrade to the 4" soon Mike.
Old Aug 30, 2010 | 01:18 PM
evo<3's Avatar
+1 for ETS FMIC and other products, great stuff guys!
Old Aug 30, 2010 | 01:26 PM
kingkorea76's Avatar
what are exact dimensions of the intercooler that fits under cusco power brace and how much shipped to 91326 for that full kit???
Old Aug 30, 2010 | 01:32 PM
Sending you a PM! The core it self is 20" wide.
Old Sep 1, 2010 | 10:09 AM
Bump!
Old Sep 2, 2010 | 04:00 PM
Bump!
Old Sep 3, 2010 | 02:49 PM
Bump!
Old Sep 3, 2010 | 11:37 PM
Mike you got a PM.
Old Sep 8, 2010 | 01:09 PM
Thanks Buddy! We are working on the new site now.
BUMP!
Michael
Old Sep 8, 2010 | 01:14 PM
Nofear23's Avatar
I'll be buying one when I have the money!
Old Sep 10, 2010 | 03:13 PM
Thanks Buddy!
Michael
Old Sep 14, 2010 | 05:09 PM
Bump!
