CBRD we've got balls...
Old Sep 13, 2013 | 08:38 AM
  #106
06MREvo's Avatar
My JB BBK-B is getting pulled off the car this weekend finally. Trying to decide if I want it converted into a BB B or C....
Old Sep 13, 2013 | 09:24 AM
  #107
boostedwrx's Avatar
What did the BBK-B make on a DJ?
Old Sep 14, 2013 | 05:57 AM
  #108
kawtipin's Avatar
I dont have one. and it was tweeked on a lil bit after the dyno session so its different now anyway.
Old Nov 1, 2013 | 09:49 AM
  #109
leecavturbo's Avatar
Anyone had idle issues with this turbo? I'm not blaming the turbo its probably because it's SO good.
We think on idle the speed of the turbo is screwing with the maf. It's idleing really rich and we can't lean it out no matter what. Changed every sensor for new.
Any tips greatly received before I have to buy aftermarket ecu.
Old Nov 1, 2013 | 11:48 AM
  #110
mrfred's Avatar
Its gotta be something else besides the turbo. Vacuum leak, fuelling, something. Was anything else changed at the time of the turbo swap?
Old Nov 1, 2013 | 12:01 PM
  #111
Engine rebuilt Fred but only change in spec per se is the turbo.
I even tried adjusting latency to try and starve petrol and lean it out ( correct way? )
No matter just sits at 10 afr. We proved reading with other and checked plugs black as
Old Nov 1, 2013 | 12:16 PM
  #112
mrfred's Avatar
That means everything came off the motor and went back on. Although its all the same parts, things can be different. Sitting at 10 AFR seems awful odd. Have you checked fuel pressure at the rail?
Old Nov 1, 2013 | 12:25 PM
  #113
Yes I have an adjustable with gauge was set as previous same pump rail injectors. We had a play with various pressures and even fitted stock reg. All gave same result.
Car always started bright as a button. We changed the lambda sensor for new item, checked cam sensor trigger correct install,new crank sensor tried 3 or 4 mafs
Smoke boost leak tested it.
Really lost but have since read a few stories of bb turbos on stock maf doing weird things so thought I'd ask
Old Nov 1, 2013 | 02:32 PM
  #114
mrfred's Avatar
The only odd interaction between turbo and MAF that comes to mind is some sort of frequency being emitted by the turbo that's affecting the MAF sensor. The notion would be that it would cause a falsely high MAF Hz and load reading. Are you seeing that, or are MAF Hz and load readings normal for idle?
Old Nov 1, 2013 | 04:10 PM
  #115
I'll grab a log and check an old log and compare Hz. Thanks Fred.
Load was as before
Old Nov 6, 2013 | 04:35 PM
  #116
mrfred's Avatar
hey chad, i see that you mentioned a titanium turbine wheel in some earlier posts. can you explain what you have going in this area? also, you have a pm and phone call from me.
Old Feb 16, 2014 | 04:19 PM
  #117
went with after market ecu in the end. turbo is doing the business though. sounds like it goes supersonic on spool
uk flywheel
heliarcpro
Apr 18, 2017 08:43 PM
CBRD
Apr 24, 2012 03:14 PM
CBRD
Apr 22, 2012 12:13 PM
CBRD
10
Jan 8, 2012 08:32 PM
CBRD
Feb 7, 2011 12:54 PM
