Boost Leak Testers, Brad Penn, Eneos, Royal Purple, ATE, Motul - Get it at STM!!!!!
If you've got a turbo car, you've probably experienced boost leaks.
Find those boost leaks the easy way with an STM Boost Leak Tester.
-- Comes with coupler for any turbo application!
-- Easiest way to ensure you're getting the air flow and boost your engine is craving
-- Price varies on turbo inlet size - give us a call today for your application's pricing!!!!
If you've ever experienced a boost leak, you've probably found that leak coming from your throttle body shaft seals. Fix it now and fix it the right way with the STM HP (High Pressure) Throttle Body Shaft Seals.
--These shaft seals replace the stock leaky seals.
--We've seen gains on our own cars of 20whp and 20wtq simply by replacing these seals.
--Works for DSM(only 1 side on 1990)/3KGT/Evo (not X)
--Offering a 20% discount for a limited time!!!! Get yours today!!!!
FLUIDS!!!!
No car works without the proper fluids. The safety and well-being of your car depends on having quality fluids at the right price.
If you've ever had serious brake fade, you know that your choice in brake fluid really does matter.
ATE Type 200 (the Amber Version of the Super Blue) has all the same specifications as the Super Blue Racing, but comes in a "Not Illegal in the US" option of Amber.
- Boiling point minimum: 536°F
- Wet boiling point minimum: 388°F
- Viscosity at -104°F: max 1,400 mm 2/5
- Designed to last up to 3 years under normal highway driving conditions
Need something to withstand your more aggressive driving style? No problem:
Motul Brake Fluids are the zenith of quality when it comes to brake fluids.
Read up on your options here:
http://www.streettunedmotorsports.co...diy_fluids.htm
Give us a call (or PM) today with your questions or orders. We're here to help you get the right product for the best price!
585.226.8226
FLUIDS!!!!
585.226.8226
When it comes to filling your car with the best oils possible - you have your pick of the litter.
There's no easy way to give a full selection of all the oil choices for your car in a single post, so I will list just SOME of the brands you can get your hands on at the lowest guaranteed prices here at STM:
- Brad Penn's Full Catalog
- Royal Purple's Full Catalog
- RedLine's Full Catalog
- Eneos' Full Catalog
- Amsoil's Full Catalog
- Motul's Full Catalog
- All OEM Mitsubishi Fluids
Find the most common choices here! If you don't see it on our site, we can surely get it and still guarantee the lowest pricing available.
If you can't find it on our site, give us a call or PM us today!!!
585.226.8226
585.226.8226
mega bump:
Do these come with the gasket? Price shipped? I'm assuming these are equivalent to the works exhale version (but better )
Looking into fixing a throttle that feels a little odd/sticky going from off throttle to tiny amount of throttle at cruise. My seals are stock anyway, so I probably should replace them
Girodisc Martin
EvoX 'For Sale' Suspension / Brakes / Handling
233
Feb 25, 2017 09:31 AM
Girodisc Martin
Evo 'For Sale' Suspension / Brakes / Handling
415
Aug 2, 2016 08:45 PM
