Dyno Results Subzero
Old Oct 17, 2004 | 12:29 PM
smackmatic's Avatar
Smile Dyno Results Subzero
I got my car on the dyno. Here are the results. I am runing the subzero base map, with a 2.5 in test pipe. what do you think of my afr? The guy working there said it was lean between 3-5K.
Old Oct 17, 2004 | 12:37 PM
alex_alex's Avatar
its probably fairly meaningless until you look at dyno charts from other evo's on that exact same dyno with the same settings and the same conditions.
Old Oct 17, 2004 | 12:43 PM
smackmatic's Avatar
Are you reffering to the afr, hp numbers, or both?
Old Oct 17, 2004 | 12:45 PM
Noize's Avatar
EvoM Administrator
HP probably. Shouldn't be too different than any other dynojet numbers, though.
Old Oct 17, 2004 | 01:26 PM
smackmatic's Avatar
Well, I hevent seen many subzero dyno charts, so I thought I would post mine. I was happy with the results.
Old Oct 17, 2004 | 07:21 PM
David@Vishnu's Avatar
Its not lean between 3-5K
Old Oct 18, 2004 | 11:54 AM
smackmatic's Avatar
Thanks for your reply, David. I feel better geting an answer from someone at Vishnu. I wasnt to sure of the people that ran the dyno. They tried to tell me that I had to get an aem standalone if I were to upgrade the cams. I guess they have never used an xede before.
Old Oct 18, 2004 | 03:12 PM
Jorge T's Avatar
That a nice improvement over stock!
Old Oct 18, 2004 | 04:14 PM
modvp's Avatar
What was your stock hp on that dyno?
Old Oct 18, 2004 | 05:54 PM
smackmatic's Avatar
I never had the stock car on the dyno, but some of the guys there said that stock evos were puting down around 230hp. They were suprised to see a car with a stock exhaust make that kind of power.
Old Oct 18, 2004 | 07:55 PM
Willie Dynamite's Avatar
I see that you are in Delaware, where did you go for your dyno?
Old Oct 19, 2004 | 02:27 PM
smackmatic's Avatar
It was the dsr dyno day at xotic motorsports. They have a website you can check out.
Old Oct 19, 2004 | 02:40 PM
Noize's Avatar
EvoM Administrator
230whp for a stock Evo? That's almost unimaginable to me!
Old Oct 19, 2004 | 02:52 PM
Ludikraut's Avatar
My stock Evo made a whopping 255whp on a DynoJet in CO ... of course that was due to the equally whopping 1.28 SAE correction factor
l8r)
Old Oct 19, 2004 | 03:11 PM
I have been to Xotic a few time and I want to take my EVO there for a baseline dyno.
