Dallas Stage 1 Install
Ok, so I just took my car to the dyno today and I'm not very happy. So far the only performance mods are the injen intake with upper i/c piping, a set of Nology Hotwires, and Iridium spark plugs. I want to order the Vishnu Stage 1, but who in the Dallas area should I go to for the install?
AFAIK, you shouldn't expect to get much of anything with an upper IC and the Injen intake, and you shouldn't get anything significant from fancy wires or the plugs. I'd expect your car to give stock dyno numbers.
What were the numbers and what type of dyno?
yeah where did you dyno and how much did you make? in answer to your question i can lend a hand with the install. i tried yahoo im'ing you but the handle didn't work. well i can help on everything but the camgears...i really don't want to feel responsible for jacking up your ride.
vincent
vincent
It was on a Mustang dyno at FIS in McKinney. Read out at 219.2 HP and 231.5 TORQUE. I knew the fancy wires and plugs wouldn't do anything, wasn't sure what the intake and piping would do. I was just planning on having more than 219.2 WHP...more like 240ish.
Originally Posted by shiv@vishnu
My suggestion is to take out the nology wires, injen intake and install the Stg 1 parts. Don't bother with the MBC.
shiv
shiv
Ditto Shiv's suggestion. No sense in fiddling with piddly mbcs and other primitive gadgets if you're even considering going the relatively high-tech Stg 1 route.
Originally Posted by tke_413
Why wouldn't I just leave those on and install the stage 1? If this is a dumb question, please be nice!!
i just dynoed my stock evo on a dynojet..........i got 220hp and 250torque...... the temp was 60 and 93 gas.......since then i installed the injen intake it feels like i lost some hp below 5000 and it pulls alittle harder above 5000.......im going to get it dynoed again with the intake on just to see
Originally Posted by Ted B
You will need to post A/F logging as well if you really want to know what's going on with the intake. Be advised.
Question is why did you spend money on parts that aren't guaranteed to make power? How much did you spend on those parts? And could you have gotten a downpipe and/or exhaust for that amount of money...
