Stg 3 30R dyno results and XEDE maps inside
Subscribe
Jan 20, 2005 | 08:00 AM
First of all, we are looking at two different graphs, one being 91oct and the other 100 oct.
The 91 oct made ~340whp @ ~21.5 psi
The 100 oct made 395whp @ ~28-30 psi
The hp taper occurs because the torque peak falls. This could very well be due to the limits of mechanical efficiency at those engine speeds, or, a decrease in turbo efficiency.
In any case, these numbers for 91 and 100 oct translate to ~398 and 462whp on a Dynojet respectively. Not too shabby!
Jan 20, 2005 | 04:43 PM
Quote: First of all, we are looking at two different graphs, one being 91oct and the other 100 oct.
Correct mine made 460ish and 400ish on a dynojet. I believe I made 391 and 335 on Shiv's rollers. Shiv can you please post up my weaker dynochart to show the consistency of the tunes.
Jan 20, 2005 | 05:14 PM
That turbo spools very nicely hitting 21.5psi at 4400rpms. What gear was the pull in?
Jan 20, 2005 | 06:54 PM
how much is it to go to stage 3 if you are already 1+?
only thing extra is turbo and injectors, right? if not, what else is included?
Jan 20, 2005 | 07:40 PM
321 stainless manifold, Lower IC pipe, Tial wastegate, New DP, MAF pipe, Turbo and injectors. Cost is in the 5K range depending on a few options
Subscribe
