Question about cams w/out tune...
Old Feb 17, 2005 | 09:02 PM
Vroompsh's Avatar
If i run the hks 264i/272e setup with cam gears adjusted to maybe -3,-3 will my car have any problems until i get my Xede? Any knocking problems? just curious before i install them..
thanks
Old Feb 17, 2005 | 09:06 PM
gsujeff55's Avatar
you have a completely stock ECU? no piggyback or nothing?
Old Feb 17, 2005 | 09:07 PM
Vroompsh's Avatar
yes completely stock ecu.
Old Feb 17, 2005 | 09:10 PM
gsujeff55's Avatar
i would imagine it would run fine, might have a rough idle and you def won't get the power out of the cams that you would with a tune. i would suggest an xede or flash before cams, it will show a greater gain in power and driveability over the cams. for sure
Old Feb 17, 2005 | 09:13 PM
Vroompsh's Avatar
ok, well i'm planning on getting an Xede soon, but i think i'm going to install the cams first..cant really wait..lol but as long as it wont mess anything up. From what i understand, the cam gears can really help smooth out idle. Thanks a lot for the input.
Old Feb 17, 2005 | 09:16 PM
gsujeff55's Avatar
they will. but, if you haven't bought cams yet, you will see a MUCH and i mean MUCH bigger gain by getting the xede first. its about hte same price as cams and gears....then, add them afterwards...you doin it *** backwards man!
Old Feb 17, 2005 | 10:19 PM
shiv@vishnu's Avatar
Totally safe to run cams without the XEDE. Just don't expect any noticeable power gains
Shiv
Old Feb 18, 2005 | 08:00 AM
evolute's Avatar
am i right in thinking that the XEDE doesn't do anything special to adjust for the cams? it's the XFlash i'd want to compensate for those, right?
and i was thinking i'd get the cams, then the XFlash - shiv says you can run cams safely w/o the XFlash, but is it safe the opposite way.....to run an XFlashed ECU that has compensated for cams w/o the cams installed?
Old Feb 18, 2005 | 08:24 AM
Correct
Old Feb 18, 2005 | 08:35 AM
evolute's Avatar
thanks!
Old Feb 19, 2005 | 04:49 PM
Vroompsh's Avatar
Shiv, I will be getting an Xede soon, but i won't feel any more power with just cams/gears? My friend Rocky, you know him (Puckadog)...he said that I should go with cams first then tune it, because i'd have to tune anyway after cams.
